Old 06-02-2015, 09:27 PM   #15
cjd
cjd's Avatar
Drives: 2017 BRZ
Alignment first. Tires second.
You can go a loooong way on that and save up for good coils. Somewhere in there you might be able to add an 8" wheel if that's where you want to end up, but if you're after something wider, you may need coils for clearance.
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (06-03-2015)
Old 06-03-2015, 12:26 AM   #16
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
make sure to buy spokes and hubs when you buy rimzzzz
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
KevinK121 (06-03-2015)
Old 06-03-2015, 12:39 AM   #17
86Vegas
Drives: 2014 Fiat 500 Abarth, frs coming
Suspension first
86Vegas is offline   Reply With Quote
Old 06-03-2015, 02:18 PM   #18
kingkenny
Drives: 2014 Toyota GT86
tires first , coilover and stiffer suspension need more sticky tires to match .
kingkenny is offline   Reply With Quote
Old 06-03-2015, 02:49 PM   #19
rlpaul
Drives: point A to point C. Screw point B!
I've always been in the Wheels/Tires first group for a few reasons:
1. The stock suspension isn't all that bad, and learning the cars limits on it before upgrading suspension is a good way to go.
2. I like having two sets of wheels for climate reasons. My OEM wheels become my winter wheels.
3. I'm pretty picky about tires. If I'm going to change the tires, might as well change the wheels at the same time.
rlpaul is offline   Reply With Quote
Old 06-03-2015, 04:18 PM   #20
fika84
fika84's Avatar
There's really only one right answer to this... both at the same time.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Racecomp Engineering (06-03-2015)
Old 06-03-2015, 05:19 PM   #21
strat61caster
strat61caster's Avatar
Originally Posted by Vracer111 View Post
Proper wheels and tires first and don't even bother with coilover suspension until you know that the stock suspension is holding the car back. Lightweight wheels with properly sized track oriented tires (read stock size or SLIGHTLY wider) are extremely capable on track with an otherwise 100% stock car...Plus just lightening the unsprung mass by 4-5lbs a corner with lightweight wheels and proper tires does wonders to improve the ride quality over how it feels stock.
I'd put money towards the brake system (the car's absolutely weakest link) and an oil cooler (second weakest link) before even thinking about changing the stock suspension in any way. Those are much more critical to have done if you are seeing any track use.
Quoting both of these to reiterate them because they are solid.
The OEM suspension is good, it can go a looong way. If you are serious about tracking then brakes are first, period. Alignment and adding camber on the front wheels via camber/crash bolts will dial out a noticeable amount of understeer and help your tires last longer on track/autoX.
Some people like building what they want to build and thrashing it around with little regard for maximizing peformance, and that's cool. imo if you want to improve your driving skills, take it slow, make each change scientific and understand what the results are so you can apply it to your future endeavors. If you throw everything on at once you can mask what the solution is or bury the problem without truly addressing it, did the new spring rates eliminate the understeer or are the tires covering it? Was it the alignment that helped you rotate on the final corner of the autox or was it the tune giving you the power to slide the back end around and are both just covering for an inefficient line?
Different strokes though.
ineedyourdiddly
cjd (06-03-2015)
Old 06-03-2015, 07:18 PM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Andrew_FRS_DD View Post
i am planning on tracking
Brakes.
cjd (06-03-2015)
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
Trade: BRZ stock rims + Michelin Pilot Super Sport for stock rims & tires + $600 Ferrari Canada Classifieds 7 05-12-2015 03:45 PM
Stock rims +coilovers +spacers +LCAs ang31ito Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-03-2014 05:22 PM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 09:56 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 03:33 PM
