| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
F Z1LLA
Drives: Lexus IS-F Series 2
Sent from my GT-N7100 using Tapatalk 2
2URGSE |
| The Following User Says Thank You to JPxM0Dz For This Useful Post: | Juanito08 (12-31-2012) |
#16 |
Great write up, just as another option rather than cutting the carpet the way the manual says. I took the center bar out and installed the two brackets. Then I marked the top of the two brackets with a silver sharpie marker and while still wet I lined up the carped and pressed down, thus transferring the silver sharpie to the rear of the carpet where the brackets were. Then I used an exacto knife to just cut two slits on each side for the bracket to poke up through. Wiped the sharpie off the brackets and pressed the carpet down over the brackets. And then finally installed the center bar. Here is a pic:
| The Following 6 Users Say Thank You to SakDiesel For This Useful Post: | Chad86 (08-09-2014), neutron256 (12-31-2012), Ornelas66 (03-15-2015), ProjectD (01-04-2013), tripjammer (04-09-2013), Tristor (02-22-2018) |
#17 |
Another Pic:
| The Following 4 Users Say Thank You to SakDiesel For This Useful Post: |
#18 | |
Drives: '04 350Z/ 2013 LR BRZ (LM)
#19 |
Drives: Toyota 86 GTS Manual in Storm Black
Thanks for uploading, seems very helpful!
I've heard from many places that the rear strut bar isn't compatible with 86s with a spare tire in the rear. Does anybody know if the rear wheel storage position is any different with the USA version of the car from the Australian version? The only difference from the USA version that I can see is that the Australian version comes with a hard rubberised boot mat that covers the wheel in a 'donut' like fashion. Obviously the mat needs to be removed to install the strut bar. Does anyone have any ideas if the rear bar will fit the Australian car? Cheers! |
#20 | |
Most of reviews and DIY I've seen didn't mention it....? |
#21 |
Drives: SWP 86 GTS 6MT
#22 |
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Another option is use whiteout. It's a bit easier to clean than Sharpie, lol. Same idea though. I still have to do mine... And gotta cut the rear cargo mat I got, smh.
#23 |
Drives: '13 GBS Subaru BRZ
Just finished my install, great write up. I had zero issues. One suggestion for cutting the foam. If you have and oscillating tool like a Fein, or Dremal Multimax it cuts through the foam like butter giving you great control and the ability to quickly shave off thing layers until you have a perfect fit.
| The Following User Says Thank You to neutron256 For This Useful Post: | tripjammer (04-09-2013) |
#24 |
Drives: 2015 Blue.Series.BRZ
Rubber mats, does it clear?
#25 |
Drives: 2019 WRX
I'm about to cut mine.. so scared im going to f*ck it up...
| The Following User Says Thank You to JMon85 For This Useful Post: | Tristor (05-01-2018) |
#26 |
Drives: 2017 Subaru BRZ Limited
I just used a utility knife to cut the carpeted mat when I did my install. My cuts weren’t perfect, but from outside the trunk looking in, it looks good. Just relax, measure twice, cut once. You’ll be fine.
| Tanabe Pics of front and rear strut bar! | PrimeMotoring | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 06-11-2012 07:02 PM |
| Front Strut Tower Bar Question | russv | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 05-22-2012 03:00 AM |
| Cusco Rear Diff. Jewelry | Blaaaack-BRZ | Engine, Exhaust, Transmission | 24 | 05-12-2012 04:28 PM |
| strut tower braces made out of bamboo?!? | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 04-02-2010 02:27 PM |
