Old 12-30-2012, 10:57 PM   #15
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by Juanito08 View Post
I know this thread is old, but I had a quick question. Does the strut bar sit flush to the spare cover? Or is there a small "gap"? Is so about how big of a gap?
There's a gap, maybe a half inch or better
Sent from my GT-N7100 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Juanito08 (12-30-2012)
Old 12-31-2012, 09:50 AM   #16
SakDiesel
Great write up, just as another option rather than cutting the carpet the way the manual says. I took the center bar out and installed the two brackets. Then I marked the top of the two brackets with a silver sharpie marker and while still wet I lined up the carped and pressed down, thus transferring the silver sharpie to the rear of the carpet where the brackets were. Then I used an exacto knife to just cut two slits on each side for the bracket to poke up through. Wiped the sharpie off the brackets and pressed the carpet down over the brackets. And then finally installed the center bar. Here is a pic:
SakDiesel is offline   Reply With Quote
The Following 6 Users Say Thank You to SakDiesel For This Useful Post:
Chad86 (08-09-2014), neutron256 (12-31-2012), Ornelas66 (03-15-2015), ProjectD (01-04-2013), tripjammer (04-09-2013), Tristor (02-22-2018)
Old 12-31-2012, 10:00 AM   #17
SakDiesel
Another Pic:
The Following 4 Users Say Thank You to SakDiesel For This Useful Post:
AGM6789 (01-09-2013), ProjectD (01-04-2013), tripjammer (04-09-2013), Tristor (02-22-2018)
Old 01-04-2013, 01:54 AM   #18
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Another Pic:
Well done. Thanks for sharing. Will be giving this a try.
ProjectD is offline   Reply With Quote
Old 01-04-2013, 05:52 AM   #19
wytcpl
Drives: Toyota 86 GTS Manual in Storm Black
Thanks for uploading, seems very helpful!
I've heard from many places that the rear strut bar isn't compatible with 86s with a spare tire in the rear. Does anybody know if the rear wheel storage position is any different with the USA version of the car from the Australian version?
The only difference from the USA version that I can see is that the Australian version comes with a hard rubberised boot mat that covers the wheel in a 'donut' like fashion. Obviously the mat needs to be removed to install the strut bar. Does anyone have any ideas if the rear bar will fit the Australian car?
Cheers!
wytcpl is offline   Reply With Quote
Old 01-09-2013, 03:25 AM   #20
ProjectD
ProjectD's Avatar
Originally Posted by Spartan65 View Post
did you install this while the car was lifted to pre load the chassis?
If this was a rule of thumb, wouldn't it have been specified in the directions? I'm asking for self knowledge, not to disagree as I am still in my "learning" phase. Thanks.
Most of reviews and DIY I've seen didn't mention it....?
Old 01-09-2013, 06:14 AM   #21
AGM6789
Drives: SWP 86 GTS 6MT
Another Pic:
I knew this was an option! I really didn't want to cut the mat like the manual says.. Was contemplating on doing this..
thanks for the confirmation!
AGM6789 is offline   Reply With Quote
Old 02-03-2013, 12:15 AM   #22
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
Another option is use whiteout. It's a bit easier to clean than Sharpie, lol. Same idea though. I still have to do mine... And gotta cut the rear cargo mat I got, smh.
sbxjap is offline   Reply With Quote
Old 03-29-2013, 11:07 AM   #23
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Just finished my install, great write up. I had zero issues. One suggestion for cutting the foam. If you have and oscillating tool like a Fein, or Dremal Multimax it cuts through the foam like butter giving you great control and the ability to quickly shave off thing layers until you have a perfect fit.
The Following User Says Thank You to neutron256 For This Useful Post:
Old 12-05-2014, 01:30 PM   #24
Lokenzi
Drives: 2015 Blue.Series.BRZ
Rubber mats, does it clear?
Lokenzi is offline   Reply With Quote
Old 04-30-2018, 10:09 PM   #25
JMon85
JMon85's Avatar
Drives: 2019 WRX
I'm about to cut mine.. so scared im going to f*ck it up...
JMon85 is offline   Reply With Quote
The Following User Says Thank You to JMon85 For This Useful Post:
Tristor (05-01-2018)
Old 05-01-2018, 10:31 AM   #26
Tristor
Tristor's Avatar
I just used a utility knife to cut the carpeted mat when I did my install. My cuts weren’t perfect, but from outside the trunk looking in, it looks good. Just relax, measure twice, cut once. You’ll be fine.
Tristor is offline   Reply With Quote
Tanabe Pics of front and rear strut bar! PrimeMotoring Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-11-2012 06:02 PM
Front Strut Tower Bar Question russv Scion FR-S / Toyota 86 GT86 General Forum 29 05-22-2012 02:00 AM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
strut tower braces made out of bamboo?!? aspera Scion FR-S / Toyota 86 GT86 General Forum 26 04-02-2010 01:27 PM
