Old 06-14-2012, 04:50 PM   #15
Racecomp Engineering
You need to include spring rates here....that's a very important piece of information to those buying springs.
- Andrew
Old 06-14-2012, 04:56 PM   #16
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
What I am going to do instead is create a topic for each item that will contain more information, such as user reviews, etc. If I try to put any more information into the list then it wraps and screws up the formatting. Grrr. Maybe I will ditch the best price thing and include spring rates instead...
Old 06-14-2012, 05:15 PM   #17
ebphoto
Drives: FR-S, NA8, S13
Fortune Auto also has coilovers available for the FR-S.
ebphoto is offline   Reply With Quote
Old 06-14-2012, 05:16 PM   #18
Or get rid of part number or something. A separate thread for each would be really cool.
Definitely appreciate gathering this info!
- Andrew
Old 06-14-2012, 05:42 PM   #19
DarrenDriven
NW Region Moderator
Already did it!
Added them.
Old 06-14-2012, 05:47 PM   #20
Sweet! Our yellow springs are 250 lbs/in front and rear. (aka 4.46 kg/mm)
- andrew
Old 06-14-2012, 06:03 PM   #21
coyote
coyote's Avatar
Drives: Slowly
Not all will offer equal rates front and rear, so they really require separate columns. Price is not a good thing to try and keep up to date on a static page anyway.
coyote is offline   Reply With Quote
Old 06-15-2012, 10:08 AM   #22
MattR
Running in the 90s
MattR's Avatar
Drives: 2014 Scion FR-S Monogram
Thanks for this thread Darren.
A tip you might want to add to the post for those wanting to convert lbs/in to kg/mm and vice-versa. Just ask Google.
For example, the RaceComp Springs: Google "250 lbs/in to kg/mm" = 4.46kg/mm
藤原とうふ店(自家用)
MattR's Tofu Runner
MattR is offline   Reply With Quote
Old 06-15-2012, 10:19 AM   #23
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
how about springs that raise the car about an inch and have a softer rate?
i wouldn't mind paying 300 or so bucks for a set of springs i can throw on in the winter rather than 3000 coilovers.
Old 06-15-2012, 06:04 PM   #24
DarrenDriven
NW Region Moderator
Good idea, I am still working out the kinks. I'll fix this soon, but too busy driving my car today to worry about it.
Old 06-16-2012, 03:40 AM   #25
DarrenDriven
NW Region Moderator
Updated Tein H-Tech specs:
Spring Rate: 4.6k-Front spring rate: 3.0k-Rear spring rate
Drop Height: -25 mm Front -20mm Rear
Old 06-16-2012, 12:29 PM   #26
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I don't know why'd you want to do this, stock the car has plenty of ground clearance for winter. BUT you don't need different springs to go taller, just some 1" poly spring spacers... The 4X4 world has been doing this for decades to level out vehicles and even gain some extra lift. I think you can even get spacers like this for some Subaru cars with "saggy but syndrome."
Old 06-16-2012, 12:37 PM   #27
simpleisbest
Senior Citizen
Drives: Scion FR-S
Can you add a list for available shocks?
simpleisbest is offline   Reply With Quote
Old 06-16-2012, 01:48 PM   #28
DarrenDriven
NW Region Moderator
Sure, post up some shock information and I will create a list for that.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
