Old 04-30-2015, 09:36 AM   #15
vroom4
I don't really drive my car hard with any traction nannys turned on, so I would never have noticed. Only time I get traction in DD mode is heavy rain...which with rs3 on their is a death trap
vroom4 is offline   Reply With Quote
Old 04-30-2015, 10:07 AM   #16
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by Createddeleted View Post
It's because you're supposed to reset the VSC sensor when you change the ride height. I'm surprised more people don't know/remember about this. You need Techstream to do this.
NOTICE:
* While obtaining the zero point, keep the vehicle stationary and do not vibrate, tilt, move, or shake it. (Do not start the engine.) * Be sure to perform this procedure on a level surface (with an inclination of less than 1 degree). HINT
When VSC sensor neutral memorization is performed, the yaw rate and acceleration sensor and the steering sensor zero point calibration are performed at the same time.
(1)Turn the ignition switch off.(2)Check that the steering wheel is centered.(3)Check that the shift lever is in neutral.(4)Apply the parking brake by pulling up the parking brake lever.(5)Connect the Techstream to the DLC3.(6)Turn the ignition switch on.(7)Turn the Techstream on.(8)Enter the following menus: Chassis / ABS/VSC/TRAC / Utility / VSC Sensor Neutral Memorization.(9)According to the display on the Techstream, perform VSC sensor neutral memorization.(10)Turn the ignition switch off and disconnect the Techstream.
The car doesn't monitor ride height. If anything was out of spec(steering angle?) it would trigger a DTC code. I'm skeptical this is the issue.
Old 04-30-2015, 10:38 AM   #17
wparsons
wparsons's Avatar
The yaw sensor would be sensitive to a change in rake, but not ride height (especially since there is no ride height sensor).
A change in rake would change how the yaw sensor "feels" yaw, but I'm skeptical that's the issue as well. You would need a pretty drastic change in rake for it to be enough difference at the sensor.
flickr
Old 04-30-2015, 12:24 PM   #18
8R6
8R6's Avatar
Drives: FRS
ive driven on a 1" drop and now a 2" drop and haven't had to "reset" any sensors. my vsc/traction control all work just the same as it did before when i was on stock suspension. does anyone have more info on this "vsc reset" process and when it's needed??
8R6 is offline   Reply With Quote
Old 04-30-2015, 01:56 PM   #19
redlined600
Drives: Fr-s
It's needed when you replace a sensor(or it gets out of wack) that the VSC system uses; steering angle sensor, yaw sensor, acceleration sensor, there might be others. The main one could be the steering angle sensor if it wasn't aligned correctly but then steering wheel would be off. AFAIK all of these will trigger DTC codes if they are out of spec.
Someone above posted the service manual procedure. Techstream is required to do the calibration.
Old 04-30-2015, 02:06 PM   #20
8R6
8R6's Avatar
Drives: FRS
i get that it's needed when replacing a sensor or it goes bad, but when/how does a suspension swap cause this? thats what confuses me...
Old 04-30-2015, 03:51 PM   #21
wparsons
wparsons's Avatar
If the rake isn't the same as it was on the stock suspension, the yaw sensor will be slightly out of whack. It has a set position for neutral, and if you alter the rake it doesn't have the right neutral point to sense yaw movement.
Like I said above, the rake change would have to be pretty substantial to notice it, but it is possible.
flickr
Old 05-01-2015, 12:18 AM   #22
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
This is really good info, Reseting is > Not Reseting if things get funny.
Old 05-01-2015, 11:05 AM   #23
350matt
Drives: toyota mr2/ Toyota GT86
is there anyway to reseet this without a techstream tool?
I've seen a video on line for steering angle sensor reset but its for a different OBD pinout than on our cars
350matt is offline   Reply With Quote
Old 05-01-2015, 07:00 PM   #24
Createddeleted
Drives: 2014 BRZ - 2004 GLI
You need techstream. My eBay cable works just fine.
The request to reset the VSC is at the end of the TRD factory install instructions for their lowering springs.
Createddeleted is offline   Reply With Quote
Old 05-02-2015, 05:11 PM   #25
350matt
will an ecutek cable work?
Old 05-02-2015, 06:27 PM   #26
wparsons
wparsons's Avatar
Probably not. You can get knock off techstream cables (and software) on ebay for cheap.
flickr
Old 05-02-2015, 10:54 PM   #27
richardabernethy
Drives: 2014 FRS
I have +3 degrees camber
richardabernethy is offline   Reply With Quote
Old 05-02-2015, 10:55 PM   #28
richardabernethy
Drives: 2014 FRS
It's because you don't have vtec
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
