#15 |
I don't really drive my car hard with any traction nannys turned on, so I would never have noticed. Only time I get traction in DD mode is heavy rain...which with rs3 on their is a death trap
#16 | |
Drives: Fr-s
The car doesn't monitor ride height. If anything was out of spec(steering angle?) it would trigger a DTC code. I'm skeptical this is the issue. |
#17 |
The yaw sensor would be sensitive to a change in rake, but not ride height (especially since there is no ride height sensor).
A change in rake would change how the yaw sensor "feels" yaw, but I'm skeptical that's the issue as well. You would need a pretty drastic change in rake for it to be enough difference at the sensor.
#18 |
Drives: FRS
ive driven on a 1" drop and now a 2" drop and haven't had to "reset" any sensors. my vsc/traction control all work just the same as it did before when i was on stock suspension. does anyone have more info on this "vsc reset" process and when it's needed??
#19 | |
Drives: Fr-s
Someone above posted the service manual procedure. Techstream is required to do the calibration. |
#20 | |
Drives: FRS
#21 | |
Like I said above, the rake change would have to be pretty substantial to notice it, but it is possible.
#22 |
The Fail Boat
Drives: CWP S.B.
This is really good info, Reseting is > Not Reseting if things get funny.
#23 |
Drives: toyota mr2/ Toyota GT86
is there anyway to reseet this without a techstream tool?
I've seen a video on line for steering angle sensor reset but its for a different OBD pinout than on our cars |
#24 |
Drives: 2014 BRZ - 2004 GLI
You need techstream. My eBay cable works just fine.
The request to reset the VSC is at the end of the TRD factory install instructions for their lowering springs. |
#25 |
will an ecutek cable work?
#26 |
Probably not. You can get knock off techstream cables (and software) on ebay for cheap.
#27 |
Drives: 2014 FRS
I have +3 degrees camber
#28 |
Drives: 2014 FRS
It's because you don't have vtec
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| Vehicle Stability Control | twostroke | BRZ First-Gen (2012+) — General Topics | 15 | 07-13-2014 11:10 AM |
| Stability Control? | ashtray | BRZ First-Gen (2012+) — General Topics | 27 | 01-24-2013 05:32 PM |
| TPMS, LSD and Stability Control | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-05-2012 04:12 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
