#15 |
Drives: Fast
I'm on KW V3's courtesy of @CSG Mike, about a 1.4" drop.
1. SPC LCA's 2. Very OEM like, adjustable, very affordable 3. I like that they are quiet like OEM. My Whitelines I had before were clunky over small hills at low speed, like making a right turn and going over a small hill where the suspension adjusts to it. It would make a clicking sound. Bugged the hell out of me, but the Whitelines are very thick and durable compared to the SPC's. About my only complaint with the SPC's since I mostly do street driving and I may see a track day once in a blue moon. |
#16 |
Drives: 2015 Subaru BRZ Limited
#17 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i had the cusco's.
just replaced for SPC because i was so fucking tired of doing alignments with cusco's. they are now for sale if your'e interested... |
#18 | |
Drives: FRS
my toe settings is almost at 0... i think it might be sliiiiiightly spec'd out in the rear. bad toe setting is what annihilates tread wear... camber wears it out unevenly, but toe just eats that shit up like no tomorrow.
#19 | |
Drives: 2005 Toyota Camry
It's like buying coilovers... a lot of people don't realize that even with locking spring perches, you'd still have things that can come loose and requires regular maintenance. The more simple a setup, the longer it will last between adjustments. -alex |
#20 |
We've installed probably 50-60 sets of SPC arms and we use them on our Project BRZ which uses KWv3 and is tracked extensively. We've also installed them on our Spec86 Cup car as well.
Good quality parts at a very reasonable price. -mike |
#21 | |
Drives: whiteout fr-s
good to know. are you guys just running the spc LCA? also are you running white line rear camber adjustment bushing ? |
#22 |
Drives: FRS
I have racerX control arms and I like them. Very solid. Easy to adjust. They are one of the few that use poly bushings which was big for me. No downside so far. I got them anodized black.
| FS: OEM Rear Lower Control Arm | MicheleAbbate | Brakes, Suspension, Chassis | 23 | 12-31-2018 03:48 PM |
| Rear lower control arm dim | theGonz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-19-2015 12:44 PM |
| SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout | quiet-k | Brakes, Suspension, Chassis | 8 | 03-22-2014 10:17 PM |
| WTB: Front Lower Control Arm and Rear Upper Control Arm | YDNA | Brakes, Suspension, Chassis | 0 | 11-10-2013 04:40 AM |
| Hancha Rear Lower Control Arm | Hancha Group | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 62 | 09-21-2013 10:47 AM |
