Old 04-22-2015, 03:11 PM   #15
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I'm on KW V3's courtesy of @CSG Mike, about a 1.4" drop.
1. SPC LCA's
2. Very OEM like, adjustable, very affordable
3. I like that they are quiet like OEM. My Whitelines I had before were clunky over small hills at low speed, like making a right turn and going over a small hill where the suspension adjusts to it. It would make a clicking sound. Bugged the hell out of me, but the Whitelines are very thick and durable compared to the SPC's. About my only complaint with the SPC's since I mostly do street driving and I may see a track day once in a blue moon.
2016 Camaro SS is offline   Reply With Quote
Old 04-22-2015, 04:35 PM   #16
mike_frs
mike_frs's Avatar
Drives: 2015 Subaru BRZ Limited
Originally Posted by adamg View Post
now im curious what you're building. no more stancy things?
Going function on this build Adam. Trying something new
mike_frs is offline   Reply With Quote
Old 04-22-2015, 04:50 PM   #17
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i had the cusco's.
just replaced for SPC because i was so fucking tired of doing alignments with cusco's. they are now for sale if your'e interested...
Jive Turkey is offline   Reply With Quote
Old 04-22-2015, 05:08 PM   #18
8R6
8R6's Avatar
Drives: FRS
Originally Posted by mike_frs View Post
Hey I just recently got some KW V3's as well
I'm wondering if I drop it 2" without a camber kit, wonder if I will eat tired like crazy :/
Debating on whether I should install the coilovers or just hold off on the install and save up and buy lca's... and would i need adjustable toe links as well?
im lowered 2 inches and my rear camber ended up being -2.7deg. ive put on about 1k miles so far and no signs of excessive wear. i plan on rotating tires (not flipping) every several months.
my toe settings is almost at 0... i think it might be sliiiiiightly spec'd out in the rear.
bad toe setting is what annihilates tread wear... camber wears it out unevenly, but toe just eats that shit up like no tomorrow.
8R6 is offline   Reply With Quote
Old 04-22-2015, 06:05 PM   #19
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by FISHBURGLAR View Post
i want to get a bit past 2 degree camber. i want consistant camber.
budget is watever necessary to get the car where i want it.
i dd my car put about 60 miles a day plus, i take back roads and beautiful hard drives almost daily.
Any adjustable rear LCA will work. Just depends on how often you want to get an alignment.
It's like buying coilovers... a lot of people don't realize that even with locking spring perches, you'd still have things that can come loose and requires regular maintenance.
The more simple a setup, the longer it will last between adjustments.
-alex
Old 04-23-2015, 08:46 AM   #20
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We've installed probably 50-60 sets of SPC arms and we use them on our Project BRZ which uses KWv3 and is tracked extensively. We've also installed them on our Spec86 Cup car as well.
Good quality parts at a very reasonable price.
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
FISHBURGLAR (04-23-2015)
Old 04-23-2015, 06:37 PM   #21
FISHBURGLAR
Drives: whiteout fr-s
-mike
good to know. are you guys just running the spc LCA? also are you running white line rear camber adjustment bushing ?
FISHBURGLAR is offline   Reply With Quote
Old 04-23-2015, 11:09 PM   #22
wootwoot
Drives: FRS
I have racerX control arms and I like them. Very solid. Easy to adjust. They are one of the few that use poly bushings which was big for me. No downside so far. I got them anodized black.
FS: OEM Rear Lower Control Arm MicheleAbbate Brakes, Suspension, Chassis 23 12-31-2018 04:48 PM
Rear lower control arm dim theGonz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-19-2015 01:44 PM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 11:17 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 05:40 AM
Hancha Rear Lower Control Arm Hancha Group Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 09-21-2013 11:47 AM
