Old 04-14-2015, 04:59 PM   #15
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
Originally Posted by evomike View Post
no it will heat up and stop working if you're actually drifting on it not just doing dumb things in a parking lot.
It's a Torsen (torque sensing) LSD, not a VLSD (viscous fluid). It's not going to "heat up and stop working" (like a diff that uses viscous coupling)...
Torsens are great for grip driving. Their only downside is if you lift the inside wheel into the air, the Torsen will act in the same way an open diff would act until that wheel regains traction. You can drift with Torsens just fine.... They just don't lockup as aggressively as what most drifters want... This is what you'd expect though. Most people who use 1.5 way or 2 way clutch-type LSDs for grip driving run them with much less aggressive settings than they would use for drifting anyway. Torsens are a good all-around diffs, and that's why OEMs use them. VLSDs suck, and that's why they aren't very common anymore.
Most pro drifters are running quick-change spools nowadays, which effectively work in exactly the same way as welded diffs... only they are stronger and safer.
Sideways&Smiling is offline   Reply With Quote
Old 04-14-2015, 05:02 PM   #16
Sideways&Smiling
Originally Posted by Pickleahoy View Post
Unless you are the next Kenny from the Block it does it's job pretty good. I have no issues holding angle with it and it grabs pretty good. Now, if your car is herra flush RACECAR 9" wide tires and you dont like that it doesnt break traction thats another story.
You don't actually think 9" wide wheels are wide, do you...? And you know Ken Block doesn't actually drift, right...?
Old 04-14-2015, 06:41 PM   #17
ZX88
ZX88's Avatar
Drives: 22 BRZ
welding a diff is for poor plebs. do it right you wont be disappointed...if you daily this car youll hate life after about a week with that welded dif.
ZX88 is offline   Reply With Quote
Old 04-14-2015, 06:50 PM   #18
shellslinger
Drives: Whiteout FRS
shellslinger is offline   Reply With Quote
The Following 2 Users Say Thank You to shellslinger For This Useful Post:
calmtigers (04-15-2015), Sideways&Smiling (04-15-2015)
Old 04-15-2015, 02:06 PM   #19
Rota
Rota's Avatar
Drives: 2015 Series.Blue BRZ
Originally Posted by Whodunit View Post
This was obvious from the beginning. Mass produced affordable light and rwd car.
It is 100% the next 240sx.
Well by design yes, but we're totally going to be finding these things in 10-15 years totally ratted out with welded differentials and people wanting $10k.
Rota is offline   Reply With Quote
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
SPEEDHUNTERS: The WELD FR-S!!! Kiske Scion FR-S / Toyota 86 GT86 General Forum 44 10-27-2014 05:17 PM
Weld Drag Rims JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 08:24 AM
Did you weld your headers on or bolted them on? Frsexxxy Engine, Exhaust, Transmission 66 06-27-2013 10:53 AM
All it needed was some JB Weld... 82mm 4g63 Other Vehicles & General Automotive Discussions 2 09-15-2011 08:12 PM
