Old 04-11-2015, 07:43 PM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Grip Ronin View Post
lol so i applied the expressions to the xml for peal requested tq. the highest the table goes is about 55. but idk how to apply this to make it open 100% lol this is such a pain in the ass. worst then maf scaling lol i raised some values at the high end and it drives the same but engine off it only opens 64% lol
noticed my injection goes port only recently on closed loop. i dont recall this happening before but i dont like it lol
Why did you adjust the Requested Torque expression?
Here is the simple explanation of how it works:
Pedal at 40% @ 3600rpm - Requested Torque = 172.8
Requested Torque base @ 3600rp = 193.5
172.8/193.5 = 0.893
Now on the Target throttle position table:
(x axis) 0.893 @ 3600rpm = ~35 Degree throttle
My Calibration Spreadsheet Has a DBW tab at at the very right that calculates it all for you. On that, the WOT threshold is known as Requested Torque base in RomRaider.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-12-2015, 09:35 AM   #16
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
172.8/193.5 = 0.893
ok so i dont have a table named requested tq base, would that be calculated torque tables A and B?
IG-Joey_Soul
Old 04-12-2015, 03:41 PM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, it obviously hasn't been defined. Which ROM are you using?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-12-2015, 10:04 PM   #18
Grip Ronin
The Mechanic
Grip Ronin's Avatar
the open flash rom 2.062 and ZA1JA00C xml.
IG-Joey_Soul
Old 04-13-2015, 02:36 AM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
These should work:
Code:
<table name="Requested Torque Base" storageaddress="13C528">
	<table type="Y Axis" storageaddress="13C4CC" />
    	</table>
<table type="2D" name="Requested Torque Base" category="Drive-by-Wire Throttle (DBW)" storagetype="uint16" endian="big" sizey="23" userlevel="1">
      <scaling units="ECU Value (Raw)" expression="x*.0078125" to_byte="x/.0078125" format="0.0" fineincrement="1" coarseincrement="10" />
      <table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P2">
        <scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="100" coarseincrement="1000" />
      </table>
      <description>This map is used to calculate the percentage of maximum torque.</description>
    </table>
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-13-2015, 10:48 PM   #20
Grip Ronin
The Mechanic
Grip Ronin's Avatar
These should work:
Code:
    	</table>
      </table>
    </table>
hm nothing is showing up. i tried it near the dbw codes and at other parts.. no new table showing in any menu
IG-Joey_Soul
Old 04-14-2015, 02:25 AM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
Place the top code with the addresses in the upper part of the definition and the part where it says table type =2D with the rest of the DBW stuff of the lower half of the definition. You'll see that the definition should be in 2 distinct halves, with a separation phrase in the middle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-15-2015, 09:45 PM   #22
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ok i got the table working thanks.
now if my requested tq is higher then my torque base say 207req/ 200base i get a 1.035 such as the stock maps are. That should be using the 1.0 raw ecu value from the target throttle position table since thats the max, but thats set to 102.4 stock and the throttle body is open only to 90%.?? There is somthing i dont understand here, do the calculated tq tables come into play?
IG-Joey_Soul
Old 04-16-2015, 02:27 AM   #23
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's why I changed the throttle angle table to be consistent with what I know from ECUtek (Max 86). I've logged and that will give you 100% commanded throttle, however the throttle angle will never show a real 100%. If it makes your life easier you could change the expression calculation for commanded throttle angle so that it shows throttle max as 100%. Just need to do some maths
I honestly don't know what the calculated Torque tables do, and from what I've read on Romraider and NASIOC I can't come to any conclusion.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-16-2015, 10:13 PM   #24
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ok so i have the table rescaled again, what it consideres 102 is max and is now 86. but i still dont understand how to remove the tapered closing after 3600rpm all the math points above 1.0 which should be 86..stock maps
IG-Joey_Soul
Old 04-17-2015, 03:11 AM   #25
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can't, it's just what the TB does.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-17-2015, 06:33 AM   #26
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Oh. I thought u said you got yours to stay open liniar. Meh then i guess ill just fix that full throttle at 70% thing
IG-Joey_Soul
Old 09-14-2020, 10:22 AM   #27
NicFromTheNorth
Drives: Subaru BRZ 2016
Thank you for the Requested Torque Base info @Kodename47. I made my throttle linear but I had to reverse engineer the torque ratio denominator because I did not have the Torque Base defined in my xml file. I wish I had seen this thread earlier and saved some time!
NicFromTheNorth is offline   Reply With Quote
AFR table nickw14 Software Tuning 9 04-01-2015 05:14 PM
f.s. Open flash table slofrs Engine, Exhaust, Bolt-Ons 3 12-31-2014 10:07 AM
2014 PAX table Scooby South Tracking / Autocross / HPDE / Drifting 11 11-26-2013 10:35 AM
Help posting a Table / Spread sheet Esoteric Site Announcements / Questions / Issues 1 07-27-2013 11:48 PM
Coffee table I made from my FRS OEM springs FR-Shadow Scion FR-S / Toyota 86 GT86 General Forum 25 12-16-2012 06:05 PM
