Old 04-15-2015, 08:45 PM   #15
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Originally Posted by huertash View Post
Excuse my ignorance, but what would be the advantage of having the Motec instead of an AEM in terms of instalation and keeping the factory features?
I would still need to make the wiring harness right?
Motec have a gt86 loom as well you can buy.
Manji is offline   Reply With Quote
Old 04-17-2015, 01:33 PM   #16
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
This is to PnP into the stock ecu connectors and wouldn't be of any use on an engine swap car.
Honestly that list could go on for days but the main one is CAN communication to keep your ABS, all factory buttons, dash functions, BCM functions, Key/Start button operation, etc. You can control literally anything with the M1; active aero, auto rev match on downshift, rolling antilag, just to name a few.
You're going to need a harness regardless of which ecu you choose but with the MoTeC you won't need to incorporate the stock ecu. Personally AEM would be way down the list of ecu choices for me. The only advantage to AEM is finding more tuners familiar with it.
Carolina Dyno is offline   Reply With Quote
Old 04-17-2015, 01:36 PM   #17
huertash
huertash's Avatar
Drives: KM4SH FRS
You're going to need a harness regardless of which ecu you choose. Personally AEM would be way down the list of ecu choices for me. The only advantage to AEM is finding more tuners familiar with it.
Thank you
huertash is offline   Reply With Quote
Old 04-21-2015, 01:14 AM   #18
rh9
Drives: red brz
im running the chasebays harness on my 2jz brz, had alot of problems in the beginning, altered some wires to make most things work..
Im running racepak instead of the stock cluster, didnt have time to bother to make the oem work, push button works, PS works with some tweaking, ill do the ac when it starts to get hot in here, but ac works buttons work right now
rh9 is offline   Reply With Quote
Old 04-21-2015, 01:15 AM   #19
rh9
Drives: red brz
Old 04-28-2015, 08:25 AM   #20
Streetthrowback
Drives: 2015 brz
A 2jz swap is and want to be in the future plans but I want to keep all my options and fuctions as if I brought the car with the motor, like traction control etc..
Streetthrowback is offline   Reply With Quote
Old 05-12-2015, 12:28 PM   #21
huertash
huertash's Avatar
Drives: KM4SH FRS
Question....what Ecu are you running and how did you hook up the Racepak with?
Old 05-13-2015, 12:32 AM   #22
rh9
Drives: red brz
IM RUNNING aem ems v2 and using v-net cable for the aem
Old 05-13-2015, 12:33 AM   #23
rh9
Drives: red brz
you can follow my instagram for some car updates @BAShar_alameer
Old 05-13-2015, 09:44 AM   #24
huertash
huertash's Avatar
Drives: KM4SH FRS
Wow!! That's a Killer BRZ man!!!! Sounds awesome!!! Did you programed the anti-lag with the AEM?
Old 05-14-2015, 01:17 AM   #25
rh9
Drives: red brz
yea im running an aem v2
LH/RH Bulkhead Wiring Harness C130NAV Want-To-Buy Requests 2 12-01-2014 05:03 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
Wiring Harness Question Sigh-on-Rice Electronics | Audio | NAV | Infotainment 0 08-10-2013 10:46 PM
3rd harness wiring? kndonlee Electronics | Audio | NAV | Infotainment 3 07-01-2012 07:49 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-16-2012 11:41 PM
