| Engine Swaps Discussion of engine swaps. |
#15 |
Toyotas don't have boxers
Drives: GTV86, ISF, TE27
Motec have a gt86 loom as well you can buy.
#16 | ||
Drives: 2013
This is to PnP into the stock ecu connectors and wouldn't be of any use on an engine swap car.
#17 | |
Drives: KM4SH FRS
Thank you Sent from my iPhone using Tapatalk |
#18 |
Drives: red brz
im running the chasebays harness on my 2jz brz, had alot of problems in the beginning, altered some wires to make most things work..
Im running racepak instead of the stock cluster, didnt have time to bother to make the oem work, push button works, PS works with some tweaking, ill do the ac when it starts to get hot in here, but ac works buttons work right now |
#19 |
Drives: red brz
#20 |
Drives: 2015 brz
A 2jz swap is and want to be in the future plans but I want to keep all my options and fuctions as if I brought the car with the motor, like traction control etc..
#21 | |
Drives: KM4SH FRS
Question....what Ecu are you running and how did you hook up the Racepak with? Sent from my iPhone using Tapatalk |
#22 |
Drives: red brz
#24 | |
Drives: KM4SH FRS
Wow!! That's a Killer BRZ man!!!! Sounds awesome!!! Did you programed the anti-lag with the AEM? Sent from my iPhone using Tapatalk |
#25 |
Drives: red brz
| LH/RH Bulkhead Wiring Harness | C130NAV | Want-To-Buy Requests | 2 | 12-01-2014 06:03 PM |
| wiring harness | so26 | Electronics | Audio | NAV | Infotainment | 5 | 10-30-2013 04:19 AM |
| Wiring Harness Question | Sigh-on-Rice | Electronics | Audio | NAV | Infotainment | 0 | 08-10-2013 11:46 PM |
| 3rd harness wiring? | kndonlee | Electronics | Audio | NAV | Infotainment | 3 | 07-01-2012 08:49 PM |
| Wiring harness | sastexan | Electronics | Audio | NAV | Infotainment | 0 | 06-17-2012 12:41 AM |
