Old 03-23-2015, 08:05 PM   #15
8R6
8R6's Avatar
Drives: FRS
Originally Posted by swarb View Post
Yeah I do my own oil changes too, even though its only been once. What form of documentation do you have in the event of warranty and they ask you to prove you did your oil change or other "checks" as they recommend? All I have are receipts and the mileage written down.
yeah, that's my only "concern" that could think of when i made the decision to do the first 2 changes on my own. i also just keep the receipts of the stuff (i just got a bulk of the oil/filters from the same dealer too actually) and the mileage it's done at. my friend is one of the managers there, so i'm hoping as long as he doesn't quit, i'm good if i need the warranty use. lol
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
swarb (03-23-2015)
Old 03-23-2015, 08:08 PM   #16
Wait, are you blaming the OP?
Pretty sure from his veiled hints that he is implying it hit something.
strat61caster (03-23-2015), stugray (03-23-2015)
Old 03-23-2015, 08:26 PM   #17
strat61caster
strat61caster's Avatar
I guess that makes sense but doesn't match with my anecdotal experience, I'm a wimp and I've rounded a ton of nuts, bolts, and screws in my life, including my FRS drain plug when I reached under the car to save some time instead of shimmying under to get closer and the ratchet slipped off.
Not nearly as bad as OP's but it doesn't take a gorilla to round an edge.
ineedyourdiddly
Old 03-23-2015, 08:35 PM   #18
Little hint from when I used to do my own changes. Take a picture holding the receipt up beside the mileage when you do the change. This way you have proof of materials, actual mileage and date stamp on the pic as evidence. May not convince the dealer but would have some weight if ever had to go to court.
8R6 (03-23-2015), hmong337 (03-23-2015), swarb (03-23-2015)
Old 03-23-2015, 09:13 PM   #19
stevesnj
stevesnj's Avatar
Originally Posted by hmong337 View Post
That was caused by using an impact gun.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Old 03-23-2015, 09:23 PM   #20
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Heffner Toyota's tool chest?
Mine actually a had a knurl imprint on 2 flats, obviously from a pair of ViceGrips! Had the dealership do the (free) service, and noticed oil spots on my driveway the next day. Took it to my local redneck garage. They had to use a breaker bar to get the oil plug out. Obviously, the dealership didn't bother to replace the washer, and tried to seal the drain by overtorquing the drain plug. New drain plug, new washer, installed by redneck garage, and all is OK.
billwot is offline   Reply With Quote
Old 03-23-2015, 09:44 PM   #21
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Look, in all my years of wrenching, how the hell are you going to round that bolt? 14mm wrench, new crush washer, DONE! Even the 14mm drain bolt on my 3sgte from year 1996 doesn't look like what the monkey mechanics at Heffner did to my FRS. Terrible.
hmong337 is offline   Reply With Quote
Old 03-23-2015, 09:49 PM   #22
D_Thissen
D_Thissen's Avatar
Good to know. I bought my car from them, but looks like they won't be servicing it. I actually use the Subaru dealership here in Tbay because the Toyota one is full of morons who have never head of Scion let alone the FR-S.
Who would you guys suggest in the GTA for service (Ill be in Whitby) that is also mod friendly?
EDIT: @hmong337 looks like they used the ole good'n'tight method.
Old 03-23-2015, 10:07 PM   #23
hmong337
Emperor JDM
hmong337's Avatar
Just do your own shit or be lucky and know a local friendly oil change shop. It's still safe to say I will NEVER EVER service with a dealership anymore. Thankfully I know a good local oil change shop and a dude I went to middle school with has his own auto-mechanic business now.
The Following User Says Thank You to hmong337 For This Useful Post:
Mr.Impreza (03-24-2015)
Old 03-23-2015, 10:46 PM   #24
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Originally Posted by Shutter View Post
this is why I drill a new hole in my oil pan each time. Prevents rounded corners
but seriously, thats pretty bad.
What you don't drop the pan and fill it through the dip stick? Man i've been doing it all wrong i'm starting to like this guy
on a serious note: my plug was rounded out when i did a change at 12k
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 03-23-2015, 10:48 PM   #25
D88
D88's Avatar
Drives: 2014 Scion FRS
Meh it's just a drain plug. I'm going to keep getting the free oil changes for life at my dealership. If they fuck something up then they're paying for the fix.
D88 is offline   Reply With Quote
The Following User Says Thank You to D88 For This Useful Post:
Tcoat (03-24-2015)
Old 03-24-2015, 03:10 AM   #26
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
At least it's stripped CCW, imagine how hard it would be to remove if they'd applied the same force when tightening. For the record I made the mistake of utilizing "free" services too where they "topped off" my washer fluid tank, except it was actually the coolant reservoir.
Decay107 is offline   Reply With Quote
Old 03-24-2015, 07:45 AM   #27
BlackMonarch
Drives: Red BRZ
Ding ding ding. Took an impact wrench to a drain plug, went *bzzzzzzzzzzt* a little too long, and now it's rounded.
BlackMonarch is offline   Reply With Quote
The Following 2 Users Say Thank You to BlackMonarch For This Useful Post:
D_Thissen (03-24-2015), Tcoat (03-24-2015)
Old 03-24-2015, 08:50 AM   #28
DarkSunrise
DarkSunrise's Avatar
Ouch. There's not even that much torque on that bolt. The Fumoto valve is pretty nice though. Clean and leak-free. Good reason to upgrade.
Also I'm really doubtful that damage could have been caused by hitting something. The drain plug is tucked pretty high up, above the skid plates. I would guess impact gun as well.
2022 BRZ Build
2013 FR-S Build
New Dealership in NYC!! Who wants an FRS?? BayRidgeToyota Dealer Cars 10 03-20-2015 11:35 AM
Dealership Help Efenys NY / NJ / CT / PA 4 10-07-2013 04:33 PM
First BRZ at my dealership michaelahess BRZ Photos, Videos, Wallpapers, Gallery Forum 6 05-19-2012 12:28 AM
got the last one at mt dealership! Mtc46jw CANADA 2 05-12-2012 09:26 PM
Anyone seen FR-S at CDN dealership? Sport-Tech CANADA 44 05-08-2012 05:02 PM
