Old 03-20-2015, 12:32 AM   #15
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by BRGT86 View Post
why wouldnt you dry the car? o_O
Mainly, the reason I was washing the car was to remove the salt.. not the dirt. Since the salt here in canada corrode and creates rust. Also, to remove the fresh dirt and grime as much as I could...
I guess its true that water spot do damage the car if you don't have filtered water.
Originally Posted by WhiteFRS69 View Post
can you post pictures of the "dirt" on your car???
I can, wait until tomorrow I promise I will post picture
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 03-20-2015, 02:18 PM   #16
tennisfreak
Drives: 2018 BMW M240i
After you wash, dry, and wax (especially if you are just using traditional carnuba based wax) apply this:
This stuff is simply amazing and will make your paint slick as ice.
Its a polymer based solution and you simply spray on and wipe off.
You car will stay clean much longer and when you go to wash it the dirt and grime will come off with minimal effort.
I put that on after every single was no matter what.
Old 03-20-2015, 02:33 PM   #17
Mikeez
Engineering Student
I put something called Jet Black, also from Turtle wax. Then I dry the car and use a compound, polisher (if it is necessary) and after all that.. I apply my sealent (NXT 2.0 Wax by Meguiar)
I just want to know the reason why the car is not coming off clean while I use the same process to wash my other cars
is it because i park in the garage?
i use the sealent and dirt stick to it that sticks firmly to the car?
Old 03-20-2015, 06:25 PM   #18
Poodles
Drives: 2015 Series.Blue
Could be as simple as you drove through something that's worse than the other cars were driven through...
Old 03-20-2015, 07:46 PM   #19
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I believe the quality of the clear coat on our cars is not as good as some others. My parents own a Kia Soul, and that clear coat is much harder and thicker than the clear coat on our cars. It makes cleaning much easier. I clayed the Kia Soul last fall, and it was so clean it was almost not needed. This is from a couple that do nothing but automatic car washes and NEVER dry it. After claying the Kia Soul, I used Carpro Reload and it still looks fantastic 6 months later.
When I do my FR-S, claying takes forever because there is so much stuck in the paint. I used Griot's Garage Best of Show wax last fall and an mostly pleased with the results. When I could during the winter, I used Optimum No-Rinse Wash and Shine, my new favorite way to wash my car. When I use a no-touch automatic car wash in the winter, I dry it and go over some of the still-dirty spots with a clean microfiber towel. This spring I will try CQuartz after correcting the paint with an orbital to try to remove most of the snow brush marks and other paint defects caused by winter.
Old 03-21-2015, 12:22 AM   #20
Mikeez
Engineering Student
Not the case, but thank you
You might be right, the clear coat isn't as good.... =3.. Also a new car has the paint fresh so it might not have fully hardened?
Old 03-21-2015, 11:15 AM   #21
Black Tire
Black Tire's Avatar
I think this is very unlikely. The paint was factory applied to the body panels before assembly. Then it was assembled in a factory in Japan, waited on a lot to be shipped to North America, waited after import for customs/etc. to get on a truck to the dealer, then sat at the dealer for a bit before you bought it. This probably took months. The paint would be fully cured by that time. You could always check the manufacturing date on the car to see how long the paint was on before you got it; it's probably listed somewhere on the driver's door frame.
Old 03-21-2015, 12:50 PM   #22
Mikeez
Engineering Student
Its most likely, but the car was built 2 month before I had possession of it. Anyways, I think my theories are right. The dirt bonds to the clear coat.
Old 03-22-2015, 04:42 PM   #23
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Originally Posted by Turbo95eg6 View Post
Your garage is prob dusty. Wax monthly and wipe down using a detail spray and a microfiber towel when that happens. And you should really dry the car... Waterspots will etch into the clear.
I learned this the hard way and it's gonna cost me about $1500 to get them all buffed out
XanRules is offline   Reply With Quote
Old 03-22-2015, 09:26 PM   #24
Vukodlac
Vukodlac's Avatar
Drives: Asphalt FR-S
Can you throw up some pictures, couple panels just to see whats going on?
-2013 Scion FR-S-
K&N drop in.
Motiv overpipe, hfc. Perrin unresonated. Stage 1 NA Tune ( Thanks Drift Office )
Vukodlac is offline   Reply With Quote
Old 03-22-2015, 10:20 PM   #25
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Here you go bro, here's how I plan keeping mine clean when i'm driving my other car.
For me, 3-7min to put on (alone or with help) and 2min to take off (while car warms up) and stashed in trunk.
Packofcrows is offline   Reply With Quote
USB port doesn't work brianc901 Electronics | Audio | NAV | Infotainment 2 08-15-2014 05:40 PM
What color would you want the FRS/BRZ to have that it doesn't have? Wilsonk227 BRZ First-Gen (2012+) — General Topics 142 05-17-2013 08:26 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
Why doesn't this light up!!!!!! jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 6 12-06-2012 11:12 AM
MT doesn't like 2nd gear Nubbs Issues | Warranty | Recalls / TSB 18 08-30-2012 08:15 PM
