Old 03-18-2015, 05:01 PM   #15
gramicci101
Off Topic
Ya by about 78 degrees!
I was just complaining about having to turn on the AC in my house, too.
Old 03-18-2015, 11:56 PM   #16
spatcha88
Drives: 2013 Scion FRS Whiteout
yeah unfortunately dealer wont cover this.. But do you guys think I should be seeing a noticeable difference by changing sparks at 41k miles??
spatcha88 is offline   Reply With Quote
Old 03-18-2015, 11:59 PM   #17
gramicci101
Off Topic
You'll see a noticeable difference by having a working coilpack; the spark plugs themselves may be just fine. What error code were you getting?
Old 03-19-2015, 09:23 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Pretty sure spark plugs are not a warranty item.
Ya the coil should be covered though.
I have a friend who has gotten the spark plugs covered after a few coil pack failures.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Tcoat (03-19-2015)
Old 03-19-2015, 09:31 AM   #19
Cool! Maybe the pack failure made the difference. Never once have I had plugs covered by warranty. Mind you we don't have to change pugs (or caps, or points, or all the other crap we had to do during a tune up) every few K miles anymore like we used too anyway.
Sportsguy83 (03-19-2015)
Old 03-19-2015, 09:40 AM   #20
Sportsguy83
Drives: Limited BRZ
I agree with you it's probably not normal for the plugs to be covered.
Tcoat (03-19-2015)
Old 03-19-2015, 09:44 AM   #21
Just wanted to make sure all the noobs that read this thread don't go running to their dealer for their "free" plug change and then rant about how they got screwed when they wouldn't do it!
You know how it goes.
8R6 (03-19-2015), Sportsguy83 (03-19-2015)
Old 03-21-2015, 03:49 AM   #22
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Ya the coil is about $100 each retail. I just checked with our catalog.
Muaddib is offline   Reply With Quote
Old 03-21-2015, 11:20 AM   #23
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Coil pack is $100, spark plugs cost roughly $80 last I checked. Coil packs need to come out to change spark plugs so there shouldn't be any real labor associated with that. That comes down to $280 worth of labor to change the plugs. That's on the high side so you may want to shop around and ask specifically about cost to change plugs for your car. My alignment shop does WRX/STI plugs for $165, and that includes the cost of plugs. Would it be a little more for the BRZ/FRS? Maybe, but I couldn't tell you specifically. I've done both, the BRZ isn't much harder.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 03-21-2015, 12:11 PM   #24
Itzed
Drives: 2014 BRZ Limited
Is he planning on doing the job by lifting the engine? That might be the cost of the extra labor.
Itzed is offline   Reply With Quote
Old 03-21-2015, 01:08 PM   #25
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Subaru spark plugs are a PIA to get to, sometimes the motor needs to be lifted, or you end up taking a lot of things out of the engine bay to have enough room to move your tools around.
I'll try and find the picture from when I did the plugs on my 07 impreza but basically the entire air intake system came out, the battery and tray came out, almost had to remove the windshield wiper fluid bottle. By the time I was able to get to the plugs an hour had already gone by.
@Itzed could be spot on with the labor charge. Either lifting the motor or removing items to get room to work
GotBRZ1691 is offline   Reply With Quote
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 10:37 AM
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 10:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 04:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
