Old 03-08-2015, 10:46 PM   #15
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
What size is the hub on the z32?
I THINK ~68mm
Celigts is offline   Reply With Quote
Old 03-08-2015, 10:53 PM   #16
Celigts
Celigts's Avatar
I'm about to brake down and buy the BBK for 08+ sti but.... you think that'll work on rears?
I'm afraid that will mess with parking brake no?
This "Brake" area is not what I know....Google hasn't been kind...lol
Megan says:
1/ Front brake and rotor,
Option1: Upgrade to aftermarket brake kits including calipers and 5x114.3 rotors.
Option2: upgrade to 08-13 stock STI Brembo brake kit (5x114.3 stock rotors), it is direct bolt on
Option3: upgrade to 2010-14 Legacy 2.5GT oem brake kit, re-drill to 5x114.3 on rotors
2/ Rear brake and rotor,
Option1, you can re-drill the original rotor to 5x114.3 and you can bolt them on.
Nothing about just going rear BBK 08+sti on rears...
I dont see why not because:
Hub=subaru 08+ sti
Rotors+calipers= 08+sti
My guess is...because parking brake issues???
Old 03-08-2015, 11:01 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What are you going ti run in the front for brakes?
Old 03-08-2015, 11:06 PM   #18
Celigts
Celigts's Avatar
Honestly...I havn't the slightest clue ...
I don't want to drop 3k on just brakes ...that's my turbo build money!
Any suggestions? I might just do the rears ... and run with a small project kics spacer in the front.
Old 03-09-2015, 01:19 AM   #19
finch1750
finch1750's Avatar
The issues is making sure brake bias stays the same as stock or the electronics will think things arent working right. I think the best bet is to contact brake companies with the specs you need and see if anything matches.
Old 03-09-2015, 04:53 AM   #20
Celigts
Celigts's Avatar
BLEH ... that's what i was afraid of ... thanks for the input.
Old 03-09-2015, 07:00 AM   #21
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
http://www.ft86club.com/forums/showthread.php?t=23512
http://www.ft86club.com/forums/showthread.php?t=44167
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Removing rear brake rotors? Kuzuri Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-18-2015 09:08 PM
WTB: Stock pads and rotors tawheed Want-To-Buy Requests 0 08-09-2014 03:26 PM
Important: DBA Rear Rotors (BRZ/FR-S) FRS2000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-17-2013 08:08 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
[WA] FS: GTS Front AND Rear Rotors stevo_12v Australia Classifieds 0 01-04-2013 08:43 AM
