Old 03-09-2015, 07:19 PM   #15
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Originally Posted by Shiv@Openflash View Post
There shouldn't be any problem with running OFM on a computer with a SSD. In fact I haven't found a hardware combination that it was unable to run on. As suggested earlier if you are running into issues, delete the existing Openflash folder that is on you C drive and do a fresh installation. Other than that I can't think of any other reason that you would b having a problem.
ive reinstalled it as admin and now. cleared c++ installs and re did them i can figure why it keeps doing this. Here is a pic of the error i get when i try to open it. Maybe some of the software developers can make sense of it
IG-Joey_Soul
Old 03-09-2015, 07:36 PM   #16
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Originally Posted by cjd View Post
FWIW, I've only run from SSD - both standard and built-in RAID (on-drive, and yeah - it failed...) and both Windows 7 and Windows 8.1
I have not tried Windows 10 yet
Sometimes odd mixes of things not fully installed can cause problems. Be sure you have the latest from the OpenFlash site (try viewing in private viewing mode/incognito to force it to ignore cached versions...) and as someone else mentioned, try uninstalling the MS libraries, reboot, then re-install.
C
just tried your plan still same thing. thanks tho
IG-Joey_Soul
Old 03-09-2015, 10:23 PM   #17
cjd
cjd's Avatar
Drives: 2017 BRZ
bummer! I also have the 64bit versions both of 7 and 8, though neither of mine are "Ultimate" - I doubt that's it though.
Unfortunately, that may suggest your SSD is starting to go. While an outside chance, it's there. It could be some other piece of hardware on the fritz - memory needing to be re-seated (if that's even possible) or something. I'm chasing the hardest to clearly identify, and there's no easy way to look into this kind of thing if you don't have extra hardware around, tools, etc.
Hopefully it's something far less miserable.
C
Old 03-09-2015, 10:45 PM   #18
cnk
Drives: '13 DGM BRZ Limited
I did some searching on that error and the only thing that I found that might be useful is to try to reinstall the .NET framework. I saw some info where others indicated that was causing the issue. Worth a shot I guess if you've already tried everything else.
cnk is offline   Reply With Quote
Old 03-10-2015, 09:29 AM   #19
Grip Ronin
The Mechanic
Grip Ronin's Avatar
C
ya weird its the same windows i ran before on this non ssd and it same on my netbook which is running the manager good. I may jus reinstall windows.
IG-Joey_Soul
Old 03-10-2015, 09:30 AM   #20
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Ya i found that in one of the searches for clr code. I did try a fresh net framework install before making this thread.
IG-Joey_Soul
Old 03-10-2015, 11:06 PM   #21
Grip Ronin
The Mechanic
Grip Ronin's Avatar
just reinstalled windows. its alot of work but the manager works now. idk what was the issue before
IG-Joey_Soul
Old 03-10-2015, 11:30 PM   #22
Tromatic
Whatever it is, MS was responsible.
Macrium Reflect. All of 15 minutes go from my current OS to a virgin install of Windows and back.
Tromatic is offline   Reply With Quote
Old 03-11-2015, 02:58 PM   #23
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Ya had most programs, songs and pics on a 1tb and only os on the ssd. Kept it simple
IG-Joey_Soul
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
OpenFlash Manager 1.14 Problem Apoc Software Tuning 30 12-10-2014 12:14 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 06:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 10:02 PM
