Old 02-26-2015, 01:14 AM   #15
johan
Drives: '14 981CS, '99 NB1
You need clay. That's the answer you're looking for here. Pick up the Meguiars clay bar kit, wash the car, and then follow the directions on the kit. For more info look at videos on youtube of the technique.
Clay is the only safe way to remove stuck on grime from the paint - it won't mar - it won't remove paint - and it'll make your paint as smooth as a baby's bottom.
johan is offline   Reply With Quote
Old 02-26-2015, 02:10 AM   #16
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Clay is after I washed the car and the I decontaminate it..
What I want is a SPECIAL SOAP that will make the dirt on my car easily removable by water. Before Clay Bar and Before even Washing the car. The pre-wash step
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 02-26-2015, 10:49 AM   #17
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
do you have access to a hose??
Old 02-26-2015, 12:35 PM   #18
Mikeez
Engineering Student
Yes, I also have a pressure washer.
This is what I do:
1. Wash car with water
2. Wash car with pressure washer (medium valve)
3. I use the soap dispenser on the pressure washer and wait 5 min
4. Pressure wash the car
Most of the dirt is like glued to my car and before actually hand washing. I want to remove 50% BEFORE I hand wash. So I need a powerful soap that will break it down and when I come to pressure wash it, it falls off.
Old 02-26-2015, 12:41 PM   #19
WhiteFRS69
WhiteFRS69's Avatar
when you mean soap dispenser... do you mean like a foam cannon??
i believe i said this before, but look into Auto Finesse products,
specially the citrus grime remover
Old 02-26-2015, 06:43 PM   #20
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Foam cannon + megs gold class = super foam.
Get some foam like this and let it sit on the car for a few minutes then pressure wash off. I really don't think you're gonna get the surface cleaner than that without touching it.
Kotu100 is offline   Reply With Quote
Old 02-26-2015, 11:28 PM   #21
Mikeez
Engineering Student
Yes you mentioned it before, but I was still looking for a powerful chemical. I will check citrus grime remover. Thank you.
The soap dispenser is like the foam cannon. However, it doesn't make the soap foam as much as the foam cannon.
Nice haha, okay thanks.
Old 02-27-2015, 08:30 PM   #22
Mikeez
Engineering Student
*Thread updated, please read main post*
Old 02-27-2015, 10:38 PM   #23
SurfAndSand
8SiX
Drives: FRS 10series
Safely is a subjective term. If you're gonna get something strong enough to eat away dirt without you touching it, and without it etching your paint then you should definitely share the info when you find this miracle product.
We all want this SPECIAL SOAP.
Find your local detailer store. They might have better information that what you're gonna find here. I know a bit about detailing, but there's nothing that I found that can do what you're asking.
SurfAndSand is offline   Reply With Quote
Old 02-27-2015, 10:58 PM   #24
Mikeez
Engineering Student
Do not take word for word, do you get what I am looking for? Not eat away, but loosen the dirt from the car for it to fall down when I rinse off.
That SPECIAL MAGICAL SOAP .
Old 02-28-2015, 03:53 AM   #25
SurfAndSand
8SiX
Hmmm...try soap canon loaded with dishwasher liquid? That stuff is expected to loosen grime without touching the dishes, right?
I would expect that stuff to sap oils from your paint and such though. You'd probably have to condition your paint after something like that.
Maybe try several passes with regular car wash soap in a soap canon several times?
Dunno. At this point, your guess is as good as mine.
Old 02-28-2015, 11:31 AM   #26
Mikeez
Engineering Student
Well thanks .
Old 03-01-2015, 08:39 AM   #27
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Do not clay unless you plan to polish after, claying the car will leave marring in the clear coat.
Instagram: stimson
Great finish using Meguiar's and Nanowax together babydriver Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-26-2015 08:28 AM
Meguiar's Hot Rims Wheel Cleaner - Safe? billyk Cosmetic Modification (Interior/Exterior/Lighting) 8 12-19-2014 03:26 AM
Dirt Cheap Vinyl ButtonMasher Cosmetic Modification (Interior/Exterior/Lighting) 6 11-17-2014 10:00 PM
Meguiar's Scion FR-S on the cover of DSport! MotivConcepts Scion FR-S / Toyota 86 GT86 General Forum 17 05-01-2013 03:50 PM
Meguiar's microfibre wash mitt Ontariofrs CANADA 8 05-01-2013 12:50 PM
