Old 02-15-2015, 02:37 AM   #15
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
I want an FRS again. Dang it!
949 Racing is offline   Reply With Quote
Old 02-15-2015, 09:10 AM   #16
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by 949 Racing View Post
Jackson Racing is deep in development for more 86 parts. Their industry leading Rotex supercharger kit is just the tip of the iceberg. Check out their website. We are working with them to bring 86 specific wheel applications to you.
949 Racing just does wheels. Our SuperMiata line of performance parts is well, just Miatas.
Originally Posted by Jackson Racing View Post
We had some fun with photoshop today. We used 15" 6UL photos, so ignore the 4 lug.
Images deleted
And for the WRBlue fans out there:
PLEASE bring out some 5 spoke wheels. Flat 5 spoke, like the Desmond Regamasters, Andrew Racing, etc...
slicktop is offline   Reply With Quote
Old 02-15-2015, 09:36 AM   #17
949 Racing
949 Racing's Avatar
I don't see that ever happening, sorry. We are a very small company. We will have our hands full for the next few years just fleshing out the 6UL product line.
Old 02-15-2015, 11:17 AM   #18
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
MMMMMMMM yes Bronze on Silver!
I'd love see those on mine.
JonAvalon is offline   Reply With Quote
Old 02-16-2015, 12:04 PM   #19
949 Racing
949 Racing's Avatar
Update: Confirmed clearance for 328mm ST40 Stoptech, Essex Sprint BBK with the 17x9.
Old 02-16-2015, 12:46 PM   #20
Vten
Drives: Too heavy
Can you confirm the 17x9 will clear the Sti brembo ? I measured around 35mm from the rotor to the caliper face.
Thx
Vten is offline   Reply With Quote
Old 02-16-2015, 01:01 PM   #21
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Thx
We will be checking the STi Brembo setup soon.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
Old 02-18-2015, 02:18 AM   #22
ayau
Drives: Some rust bucket
Since these wheels will be priced close to the RPF1, can you comment on the durability of the 6UL wheel with respect to the RPF1?
Old 02-18-2015, 07:18 PM   #23
949 Racing
949 Racing's Avatar
In the same window. The RPF1 is a gravity cast and flow formed wheel. It's the only gravity cast flow formed wheel on the market. Virtually every other aftermarket wheel that is flowformed (including the 6UL) is from a low pressure cast blank, typically an a356.2 or .0 casting alloy, then T-6 heat treated. The RPF1 has a stepped barrel to lower weight and reduce loads on the spokes. This design allows Enkei to achieve the VIA 620kg or 680kg load rating for the 5x114.3 pattern with gravity casting and the low weight. The gravity casting not only reduces manufacturing cost, the lighter weight means less aluminum, which also reduces cost. That's how Enkei is able to offer one of the lightest aftermarket wheels. They trade brake clearance and disc strength for barrel strength, low weight and cost.
In practice, the RPF1 appears to be a very durable design. Almost no reports of premature failures. The few we have seem deform from abuse had bent center discs but the barrels were still round. Meaning the entire barrel kept its shapes but was no longer centered on the hub. This type of deformation would be the expected final failure mode of this design. The few broken or cracked RPF1's I have seen seemed to have failed from abuse or a crash, not any design issue. The bent ones were all just dropping a wheel of a race track or hitting a track kerb too hard. Almost every bent one had a round barrel, just sorta clown wheel in relation to the hub, like a socket on a wobble drive ratchet extension.
The 6UL has also proven to be highly durable design. Over 25,000 in use, most of which get raced or driven on race tires at some point. We had reports of a few wheels with cracked spokes on certain 15" sizes back in 2011 so we added some material to strengthen the wheel and recertified them with VIA. Other than that, the 6UL has proven to be extremely robust.
The 6UL provides better brake clearance, has a super strong disc, costs about the same but weighs a bit more. That extra weight is our chosen compromise. We know that 1lb will never be felt by the driver or on a lap timer. Of course, some drivers see that 1lb and base their entire decision on it.
So, couldn't tell you which is stronger. My guess would be with the same abuse, the RPF1 would bend its center and the 6UL would bend its rim.
Old 02-19-2015, 02:36 AM   #24
Best response ever.
Old 02-19-2015, 04:35 AM   #25
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I almost wept at that reply. Even though I have 2 sets of RPF1s I am tempted to order a set (17x8) just repay 949 Racing for that response.
Old 02-19-2015, 11:06 AM   #26
ayau
@949 Racing, thanks for that informative post. Looking forward to seeing what the offset will be for the 17x9 5x114. It'll be for the MY15 WRX. Hoping it'll be +45 or greater (more positive).
Old 02-21-2015, 09:50 AM   #27
orangeblue
Drives: Whiteout
There's a pretty big gap between the MSRP on RPF1s and the actual market price, which is under $1000 for a set. Hopefully price and offset will be comparable.
orangeblue is offline   Reply With Quote
Old 02-21-2015, 10:02 AM   #28
s2d4
s2d4's Avatar
Offset?
17x10, 17x9, 6ul, 949 racing, jackson racing, track, wheels
Aside from 2015 Acura NSX and Toyota Supra, what else in 2015? stockysnail Northwest 7 01-13-2015 02:30 AM
"2015" FR-S Issues SquadRogue Scion FR-S / Toyota 86 GT86 General Forum 54 12-17-2014 06:20 AM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 01:26 AM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
