Old 02-13-2015, 02:55 PM   #15
alv012
I had the same issue on a 2013 (03/13 manufacture date) around 19k miles. The sound is always much worse in hot weather, especially here in Texas.
Took it to dealer (different from the dealer I purchased from since I now live in a different city) and they wanted to replace the master cylinder. It was clear to me they were just cheaping out on the warranty work fix but I didn't fight it. Clutch squeaked again when I started the car in the service bay so I left it another day, but when the mechanic tested it (in the early morning when it was still cool outside)and it didn't squeak, they gave it back and said they'd make a note in the car's file that I still think there's an issue.
I decided to stop wasting time with it unless there was an actual problem shifting. 10k miles later no problems but the noise is still irritating. My recommendation to anyone who wants to get it fixed is take it when the weather is warmer and the car is warm so the noise is more easily reproducible. I'm moving back near my purchase dealer in the summer, so I think I might try again, because what better way to spend a lovely summer day than fighting for warranty work with your dealership?
alv012 is offline   Reply With Quote
Old 02-13-2015, 05:05 PM   #16
stevemp5
Drives: scion fr-s
Originally Posted by axelo View Post
Bingo....kyodo nailed it...its the exact same noise as in the first vid....weird, i've been searching for a month now and didnt see that thread...
I'm gonna also show this vid to mechanic in the dealer!!!! Thanks so much!!!!
What kind of lubricant did you use...and can you explain exactly were did you sprayed?
Exact same sound on my video man! This morning was cold so the sound change a little bit! Dealer spray stuff on mine to but 2 days later, the sound came back.. after that, dealer change my clutch slave and after 7 month, no sound yet!
stevemp5 is offline   Reply With Quote
The Following User Says Thank You to stevemp5 For This Useful Post:
axelo (02-13-2015)
Old 02-13-2015, 06:22 PM   #17
kodyo
Drives: Scion FR-S
I wrote it in one of the posts in that thread. I basically just spray lubricant randomly in the housing. Risky, but it worked for me. I'll never take my car to a dealership again. The clutch is so easy to DIY switch yourself that I'll do that if it comes down to it (and replace/grease the offending parts).
kodyo is offline   Reply With Quote
The Following 2 Users Say Thank You to kodyo For This Useful Post:
axelo (02-13-2015), Ultramaroon (02-13-2015)
Rubber/Tire Sound after lowering springs JohnAyySays Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2014 09:16 PM
Rubber Plug For Sound Generator Tee Uniquedetail DIY (Do-It-Yourself) Guides 4 08-20-2014 11:10 PM
Window rubber seal causing squeaking sound? l0aded Issues | Warranty | Recalls / TSB 4 08-15-2014 04:08 PM
Sound from Clutch KingRohan Issues | Warranty | Recalls / TSB 5 10-17-2012 10:10 PM
Rubber Plug for Sound Generator Tee Uniquedetail Engine, Exhaust, Transmission 3 10-10-2012 12:18 PM
