Old 02-20-2015, 06:32 PM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by JohnJuan View Post
Doesn't PN usually stand for Part Number?
Maybe it does but given the size of operation that I think RacerX runs I didn't think they would need part numbers. Hence my question.
Old 02-20-2015, 07:00 PM   #16
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
It is a part number for sure
mkivalex is offline   Reply With Quote
Old 02-21-2015, 02:02 PM   #17
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Could you please tell me what "PN:RX5-02041" refers to?
Why have you decided have only one mounting hole in the middle of the arm? Doesn't this mean you will have to make 2 different arms for left and right?
It is a part number.
The prototype control arm did use two mounting locations and allowed it to be installed on either side of the car. You can see in the screen shots that the pocket now has a rib inside of it, and the control arms are now side specific. Yes, it is a little bit more machining but not too bad.
Yes, we are a relatively small operation. 5 of us in total, however we are quite efficient and effective at manufacturing. The part numbers allow us to do a number of things, most of which is on our end. The part numbers relate to our SKU on the website, it allows us to keep inventory and more importantly generate a bill of materials or BOM.
I think we have just over 100 parts that we sell from our website, we currently stock all FR-S/BRZ/GT86 parts. Its not an issue keeping track of just the 100 parts, the issue is keeping all of the components and items needed to ship those parts. This means we have to keep a lot of hardware, fittings, hoses, and numerous other items on hand. It also lets us know when we need to make more simple items like hex adjusters for suspension components.
I guess thats the burden we carry when we make the majority of the parts we sell. Hope that sheds some light on the subject, and may have been more info than needed.
Jeff@Racer X Fab is offline   Reply With Quote
The Following 5 Users Say Thank You to Jeff@Racer X Fab For This Useful Post:
Calum (02-21-2015), Captain Snooze (02-21-2015), Hyper4mance2k (02-21-2015), JohnJuan (02-21-2015), Turdinator (02-24-2015)
Old 02-21-2015, 03:13 PM   #18
Captain Snooze
Drives: Red Herring
@racerx1715
Thank you for the detailed explanation.
Old 02-24-2015, 05:16 PM   #19
sunset_blvd
sunset_blvd's Avatar
Drives: Lava 2014 Scion FRS
Ok, so let me try to understand the two options you guys offer:
New LCA's $550-ish
-independent adjustment of Camber and Caster
-.75 of roll center adjust built in
-Weigh 5lbs 2 oz.
- Anti-dive built in
Chromoly LCA's $609-659
-Adjustable camber- fixed caster
- Weigh?
- one piece construction is more solid
- Up to 2" of roll center adjustment
- Replacement bushings for increased precision and feel
Am I missing something, or am I only saving $100 or so just to make it a bit easier to alingn?
sunset_blvd is offline   Reply With Quote
Old 02-25-2015, 10:45 AM   #20
Jeff@Racer X Fab
New LCA's $550-ish
-Weigh 5lbs 2 oz.
- Weigh?
Your statement sums it up pretty well. The chromoly control arms weigh 6 lbs, 3 ounces. The aluminum arms are quite robust and offer a total weight savings of 2 lbs. For the guys that want to use their car as a daily driver with some track sessions on the weekend the aluminum arms are a perfect fit.
Shortly the Roll center will be a separate option, and will be a common kit that will work with both of the control arms we offer as well as the OEM control arms.
Old 02-25-2015, 11:17 AM   #21
Calum
That Guy
Drives: 2013 asphalt FRS MT
You have my attention, sir.
The Following User Says Thank You to Calum For This Useful Post:
Koa (02-25-2015)
Old 02-25-2015, 11:20 AM   #22
Koa
+1
Old 02-26-2015, 05:11 AM   #23
Captain Snooze
Drives: Red Herring
According to the RacerX website the caster is also adjustable on the CrMo arms.
They aren't one piece. Looking at the pics they are welded 4 piece without the joints.
Jeff@Racer X Fab (02-26-2015)
Old 03-09-2015, 10:06 AM   #24
Jeff@Racer X Fab
Front lower control arms done!!
We finished machining our updated design last week. Here are a few pics of the new design. We are sending out a few sets for anodizing this week and we should have the final product up on our site shortly for those that are interested.
As always if you have any questions or comments please let me know.
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
DIY Changing Cam Plate Racer X fabrication Mr. DIY (Do-It-Yourself) Guides 0 08-06-2014 12:56 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! Jeff@Racer X Fab Groupbuys 74 06-23-2014 09:08 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
