Old 02-03-2015, 09:57 AM   #15
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Originally Posted by geek808@outlook.com View Post
Thanks...so I wouldn't need to upgrade the stock amp with those speakers?
Any other suggestions on speakers/amp for a budget of $300.00? Thanks
Will not work.
Stock setup is as follows:
Dash speakers - mid/high run off stock HU
Door speakers - woofers ONLY run through an amp in the trunk that FILTERS mid/high frequencies.
The guy who recommended it had an aftermarket HU, likely running these through the aftermarket HU directly.
From what I understand about the stock audio system, your best bet on your budget is to get a set of components that will fit the dash and not touch doors, or a set of components w/ woofer/midrange in door and tweeter in dash and all stock front speakers. Both will likely need to be run off a small amp, but can be done in your budget if you're doing all the labor.
Last option would be to locate and remove stock amp, replace with regular 2ch amp, use that to drive full range door speakers.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-03-2015, 01:55 PM   #16
meWant
Drives: '16 BRZ Limited
Originally Posted by brandonblt2 View Post
yea looking at them they should be since they're 2ohm speakers. I used metra 72-8104 for wire connectors easy plug and play. The spacer I used was Scosche 6.5" spacer but this one required modifications to use so I would recommend going up a size.
Amazon.com : Scosche SAT6 Speaker Adapter for 2000-Up Toyota Echo/Avalon : Vehicle Speaker Installation : Car Electronics
Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics
So if I'm understanding this correctly, I'd be able to use the factory wiring with the speakers if I use that speaker connector? The connection would be factory wiring - > speaker connector - > speakers?
meWant is offline   Reply With Quote
Old 02-03-2015, 02:02 PM   #17
DAEMANO
Time Traveller
Do this with ~$100.00 - $150.00 and keep your stock components. You'll be amazed
http://sounddeadenershowdown.com
Old 02-03-2015, 03:00 PM   #18
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Originally Posted by aznatama View Post
Will not work.
You are flat out wrong these speakers are running off the stock amp in the trunk. They don't require an additional amp or headunit and Im referring to the door speakers not the ones in the dash.
brandonblt2 is offline   Reply With Quote
Old 02-03-2015, 03:09 PM   #19
aznatama
aznatama's Avatar
Are you sure? from what I understand, the door speakers are woofers only, and the factory amp has a low pass filter built into it. Unless you can disable the low pass filter, which I don't think you can.
Also, from Crutchfield website:
"The factory woofer(s) in [the doors] receive only bass frequencies from the amplifier. Replacement aftermarket speakers will only reproduce bass."
'14 BRZ LTD MT DGM
Old 02-03-2015, 03:13 PM   #20
brandonblt2
Looking at those speakers it looks like it has something that might require you stripping one side of the metra connector. But yea either way using the connector you unplug the speakers and plug in the new connector then plug that into the speakers. Its really simple when you see it.
Old 02-03-2015, 03:24 PM   #21
brandonblt2
Yea I'm pretty sure I just plugged these into where the stock speakers were no mods or anything to the headunit. So im certain they are powered by the amp only. Another guy on the forum is running the same speakers with a stock headunit and amp.
Old 02-04-2015, 02:42 AM   #22
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Will not work.
I also read somewhere that the door speakers are woofers that run off the stock amp. Would it be better sounding if I put in a 2 channel amp to run door speakers? Or a 4 channel amp to run door speakers and front deck speakers? I like my music cranked up while I'm driving. I don't wanna spend big bucks. My other Scion car stock audio sounded much better than the FRS.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-04-2015, 12:14 PM   #23
aznatama
aznatama's Avatar
Best option IMO is to replace dash and door speakers with a 2-way component speaker system, mounting the tweeter in the dash, and woofer in the door. Run it off a 2ch amp w/ speaker level inputs. The only problem is that this may be pushing your budget depending on if you want all new or can settle for used amps, and if you install it yourself (amp will require power cabling.
Although I haven't explored the possibility, it *may* be possible to utilize the stock amp wiring and location instead of running new wires for power and speakers.
'14 BRZ LTD MT DGM
Old 02-04-2015, 12:16 PM   #24
aznatama
aznatama's Avatar
It would work, but would likely be woofer frequencies only, tweeters would not be outputting any sound. I'd check to make sure by playing a high pitched test tone to see if you get sound from the doors.
'14 BRZ LTD MT DGM
Old 02-04-2015, 01:26 PM   #25
brandonblt2
Nope the tweeters are outputting sound, the higher frequencies are actually slightly over powering the bass. I see where you are coming from but considering I have both installed and did the work myself I can tell you they are plug and play.
Old 02-04-2015, 01:29 PM   #26
aznatama
aznatama's Avatar
That's weird. If that's the case, makes things easier. I'll have to look into this some more.
You have all stock wiring? Nothing changed from using the aftermarket Hu?
'14 BRZ LTD MT DGM
Old 02-04-2015, 02:09 PM   #27
brandonblt2
I used the metra connector I mentioned and thats about it. Headunit uses the all the standard wiring in the old one used, it was a plug and play.
Heres my headunit I have nothing special in terms of audio
http://www.eonon.com/Car-DVD-Players...ta/GA5167.html
Old 02-04-2015, 02:22 PM   #28
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Do you have any pictures of that installed?
JohnJuan is offline   Reply With Quote
Door speakers upgrade / replacement mike_ekim1024 DIY (Do-It-Yourself) Guides 13 02-17-2015 07:29 PM
New speakers all around! EightSix93 Cosmetic Modification (Interior/Exterior/Lighting) 14 01-28-2015 12:20 AM
Door speakers don't work after HU upgrade BigJyoungblood Electronics | Audio | NAV | Infotainment 18 05-30-2013 11:46 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
Thoughts on the BRZ radio/gps/speakers - Should we upgrade? dorkymork Electronics | Audio | NAV | Infotainment 21 01-30-2013 11:04 AM
