Old 02-02-2015, 08:57 AM   #15
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
It's only high when it's cold. I think @BatStig means you're measuring oil pressure upstream of the oil filter but either upstream or down, it will be above 100 PSI when it's stone cold. Modern-day precision manufacturing.
Thank you for clarifying my vague post! Measuring oil pressure from a sandwich plate at the filter, versus a more ideal location like the galley, will always read a bit high.
Originally Posted by wootwoot View Post
Took the car out for a spin. Got the water temp up to 200F. Oil was warm as well (of course). Saw 20psi at idel and 70psi at 3000rpm. Still seems high to me.... Is that about right? Or could I have an issue with my sender?
What temperature was your oil? Coolant only takes about five minutes to get up to operating temperature, while oil can take ten to fifteen minutes. As temperatures rise, pressure will keep dropping.
I haven't driven my car since the end of October, so I can't give you my exact pressure numbers, but this all sounds perfectly normal to me.
BatStig is offline   Reply With Quote
Old 02-02-2015, 09:01 AM   #16
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
the numbers are in line with my car as well. I have the innovate MTX-D gauge and the TRD sandwich plate, and it will stay pinned at 100 when driving until the oil temperature starts to normalize (10-15 minutes, like what was said).
malave7567 is offline   Reply With Quote
Old 02-02-2015, 01:00 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
With apologies to Kenny Rogers & Dolly Parton.
lol
Old 02-02-2015, 01:16 PM   #18
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
The innovate only reads up to 100 psi, its not uncommon to see 120+ psi on cold starts. What weight oil are you running?
Im running 5w30 and i see 36 psi @ 185F which is abnormally high.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 02-02-2015, 03:06 PM   #19
wootwoot
Drives: FRS
0w20 Motul 8100
wootwoot is offline   Reply With Quote
Old 02-02-2015, 03:32 PM   #20
#maverick#
#maverick#'s Avatar
0w20 Motul 8100
[ame="https://www.youtube.com/watch?v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame]
That should provide some good insight on oil pressure and weight @ various temperatures
Old 02-02-2015, 03:47 PM   #21
Dezoris
Dezoris's Avatar
You would have wanted a gauge that can read to 150psi.
Cold starts can put pressures up to 120-130psi depending on oil grade and oil temps.
For 0w20 you won't see normalized oil pressures until around 175F.
For 10w30 it's around 190F.
@wootwoot
Old 02-02-2015, 03:58 PM   #22
#maverick#
#maverick#'s Avatar
@wootwoot
Dude... is that your video?
Holy shit, you and that other dude (Turbowski) are hilarious LOL
Where in IL are you at?
Old 02-02-2015, 04:00 PM   #23
wootwoot
Drives: FRS
Cool. Thanks guys. I'll likely keep the gauge I have. It will still give me the info I need once the engine is warm. I may change the location of the sender at some point but it seems all is well with my oil pressure and that is the important thing. Thanks again boys!
I'll also mention I am very happy with my liquid to liquid oil cooler at this point.
Old 02-02-2015, 04:01 PM   #24
Dezoris
Dezoris's Avatar
Yes sir that yet another frs video. Glad you enjoyed.
Right now I am in northern illinois, near Algonquin/Crystal Lake area.
Old 02-02-2015, 04:03 PM   #25
#maverick#
#maverick#'s Avatar
Haha Sweet!, Im often staying by Schaumburg, if you guys need a test dummy for videos you can use my car :P
Old 02-03-2015, 03:28 PM   #26
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
I used to work in Crystal Lake, I'm pretty sure I've seen your car around on Randall before. I got mine in December of 12 and was one of the first in the Mchenry area that I saw, and I remember seeing a red one and thinking "Hmmm that's a nice car...wait, holy shit, another FR-S!"
Good times
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 02-03-2015, 06:39 PM   #27
Dezoris
Dezoris's Avatar
Good times
I am pretty sure I saw you, a few times, there was only one other red FRS and he worked at DSW in Algonquin.
Old 02-03-2015, 06:46 PM   #28
Xinshadow
Haha I think I'm the only ultramarine with a UEL setup out here, so I'm kinda hard to miss these days! You should head up to Streamwood for for their Wednesday night Sonic meets at Mxpi when they start back up, it would be nice to have some more 86 love out there!
Tire Pressure Sensors Question NoFlush Mid-Atlantic 5 02-07-2014 06:03 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 12:54 PM
Oil Pressure Sender Unit Fitment Question Captain Snooze Engine, Exhaust, Transmission 2 07-06-2013 12:41 AM
new rim/tire. question about bolts pressure? and etc WATCHMEHEAL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-25-2013 05:59 PM
