Old 02-04-2015, 12:33 AM   #15
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by Eski View Post
Nobody know's the car better than the manufacturer. However you can use different types of coolant other than just the one the manual states. You want to stick with the same color ofc unless you do a system flush.
@Ultramaroon knows what he is talking about, look at your radiator cap or reservoir cap for small leaks, even apply a pressure tester if you cannot find the leak. In theory, metal on metal parts should never wear out as long as the proper lubrication is applied. (This means regular maintenance and services, and checking fluid levels and contamination regularly.)
Agreed.
Though, I believe the key is preventing contamination in the first place.
N1rve
Old 02-04-2015, 12:48 AM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
Meh. Overrated.
Coolant, Anyone tried this?? stevo_12v Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-27-2016 04:50 PM
low coolant BRZPDX Northwest 17 06-06-2015 01:42 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-19-2013 11:43 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
