#15 |
Drives: 14' Frs Raven
Just try Chevron it has definitely helped mine out. The idle in these cars are fairly rough so I wouldn't worry too much on that.
| The Following User Says Thank You to Marco_86 For This Useful Post: | Jake_86 (01-30-2015) |
#16 |
Drives: BRZ Limited
I think an aftermarket intake can affect MAF scaling, which may affect your idle. I wouldn't be the one to ask if that is 100% the case. One more reason to get a tune though. An exhaust shouldn't affect this at all.
| The Following User Says Thank You to TheVoiceOfReason For This Useful Post: | Jake_86 (01-30-2015) |
#17 |
Drives: BRZ DGM Limited
Some have found that adding 2-cycle oil to the gas can make the chirps much less of an issue, supposedly but adding lubrication to the high pressure fuel pump:
http://www.ft86club.com/forums/showthread.php?t=21980 |
#18 |
Drives: 2013 Firestorm FRS
Chirps:
Just stop. They are not harmful, but with the rate of their discussion on this forum you would think it gonna kill the last known bison. Dont try switching between 900 different gas stations, don't add bs/garbage/additives to the fuel, dont participate in voodoo, do drugs or replace every part trying to make it go away. Just live with them. They are here to stay. Low Idle: Common issue. If they dealer will flash the computer to see if that helps. If they won't /it doesnt help, pickup an openflash tablet. They have "canned" tunes that you can choose based on your mods, and should help the idle issue. Final note: Intakes don't seem to play real well with the car since most of them mess with the MAF readings, so that could contribute to hesitation/running issues. Catback won't effect anything, other than making you sound cool (good thing). |
| The Following 5 Users Say Thank You to continuecrushing For This Useful Post: | billyk (01-30-2015), Jake_86 (01-30-2015), kch (01-30-2015), TheVoiceOfReason (01-30-2015), Ultramaroon (01-30-2015) |
#19 |
My car idles like, uhm, a car that idles perfectly. I do have the OFT, and my current tune is based of the latest ROM (B01D) IIRC. The rough idle issue was addressed several ROM editions ago.
OP, go to the dealer, tell them you have the rough idle issue and would like the latest tune. If they won't do it, ask around and see if any of your fellow owners have ROMRaider or an OFT. They can flash the latest stock tune for you. ROMRaider |
| The Following User Says Thank You to Tromatic For This Useful Post: | Jake_86 (01-30-2015) |
#20 | |
Drives: BRZ Limited
#21 |
#22 |
| The Following User Says Thank You to Koa For This Useful Post: | TheVoiceOfReason (01-30-2015) |
#23 | |
Drives: 13 FRS Satin
Unless yours has been modded, then drive on son. EDIT: Whhops, didn't read the other comments/ Ignore this one. |
#24 |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) — General Topics | 20 | 05-22-2014 06:40 PM |
| CEL, Skid Light, Rough Idle ... | SherbFrs | Issues | Warranty | Recalls / TSB | 8 | 07-18-2013 06:43 PM |
| Looks like CEL/Rough Idle is getting a lot more attention. | wawro569 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 10-06-2012 12:24 AM |
| Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 10:28 PM |
