#15 |
My opinion goes back and forth between simply young and naïve or really, really good troll all the time!
I apparently need a more sensitive Torllometer as mine only goes to 10,000 disbelievawatts and Squady may be coming in higher.
#16 | |
#17 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | brandonblt2 (01-22-2015), Koa (01-22-2015) |
#18 |
No Money, No Problems
He's like the ex who can't get over her so he keeps trying to talk bad to the other guys who are having fun...
| The Following 2 Users Say Thank You to LucidMomentum For This Useful Post: | chas3wba0 (01-22-2015), Ultramaroon (01-22-2015) |
#19 |
And judging by the cars that he lists now he is also the guy that after the divorce hooks up with the high priced, high maintenance slut that looks really good so he must show off even though the other guys may know better.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (01-22-2015) |
#20 |
Ridge Racerrrrrrrrr
Yes, sharp prolonged turning at speeds will suck oil away form the uptake and if you are FI and pulling additional oil to a turbo you will want to install a baffle to help mitigate this.
#21 | |
Drives: 2013 GBS BRZ Limited
It has zero to do with HP, EXCEPT - that High HP engines require more consistent oiling due to greater forces within the engine (which has little to do with lateral G-force) So High HP engines are more susceptible to oil starvation. Back on topic: IF you have oil starvation issues (you probably wouldnt know it unless you have an oil pressure sensor and log the data), then the solution for racers is an accusump. If air is ingested by the sump pickup, the accusump will "burp" extra oil to keep the pressure up until the bubble clears the system. Of course, the accusump can only do this for a few seconds, so a long sustained curve could still cause starvation. Of course, the BEST solution is a drysump system with a resivoir & dual oil pumps. |
| The Following User Says Thank You to stugray For This Useful Post: | Pete156 (01-22-2015) |
#22 |
Remember
Drives: 2015 Asphalt
My reaction to Squadrogue threads.
This is my 17th car. Most fun so far!
| The Following 5 Users Say Thank You to Defuser For This Useful Post: | 1GiantTurtle (01-22-2015), chas3wba0 (01-22-2015), civdaddy (01-22-2015), PandaSPUR (01-27-2015), Ultramaroon (01-22-2015) |
#23 | |
Bitter breakup huh? I'll bet it was repossessed and you just dont want to admit it.... |
#24 | |
Pics or it didn't happen, anyways. |
#25 |
At least kiichiro is claiming some kind of knowledge, the rest of you are armchair quarterbacking about your daily drivers.
And what he says makes sense, in this car you will likely fuel starve before you run into oil issues on stock powertrain. |
| The Following User Says Thank You to strat61caster For This Useful Post: | kiichiro (01-22-2015) |
#26 |
Drives: frs
Anyone thought at that speed the car can oversteer?
#27 |
Drives: Exige, Miata, Ghia
The OP is why I have no hope for this country.
#28 |
Dismember
Drives: 2013 Red Scion FR-S
People like CSG, Robispec, and Element have cornered faster than you probably ever will without reporting oil starvation from turning. Element has dealt with oil pressure issues, but that's due to engine power, not turning.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | strat61caster (01-22-2015) |
| Auto launch blows! | feldy | Engine, Exhaust, Transmission | 83 | 04-14-2017 10:42 AM |
| Dr. Destructo blows a rocker apart | Element Tuning | Engine, Exhaust, Transmission | 82 | 12-04-2015 03:00 PM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
| This blows... | finch1750 | Electronics | Audio | NAV | Infotainment | 19 | 06-21-2012 12:03 PM |
