Old 01-06-2015, 10:02 AM   #15
SpeedFromSwede
SpeedFromSwede's Avatar
Drives: WRB BRZ
V1.5x OFT stage 1 tune or V2.062 Stage 1 OFT tune. The V1.5 had offset maf scaling.
If you not already use the V2.062 stage 1 rom if your going to edit maf scaling.
That might have been my problem all along. I've been using the v1 tune with edited maf scaling. I didn't really understand the difference between the two.
SpeedFromSwede is offline   Reply With Quote
Old 01-06-2015, 10:24 AM   #16
mad_sb
Drives: 2013 Asphalt FR-S
make sure you use the correct XML files for the v2 maps, they require specific v2 definitions.
it took me a few attempts to get to the v2 stuff, too many old links floating around and indexed on search engines... this is the correct current download link: scroll to the very bottom for the v2.062 ots maps.
Old 01-06-2015, 10:26 AM   #17
SpeedFromSwede
Drives: WRB BRZ
I actually created an edited v2 stage 1 tune but wasn't sure if I could use it on my car (I used the correct v2 xmls to edit it). Can you explain the difference between v1 and v2, just a newer updated rom?
Old 01-06-2015, 05:34 PM   #18
steve99
For A01G roms the v1 and v2 tunes are still based on A01G maps.
so should be no problems, however use the V2 deinition files that come in the download file or editing v2 maps.
the v2 maps are better. especially stage 1 tunes , better afr control and less intake rasp arround 4000 rpm due better cam timings, slightly better top power
you will still likely have to do the maf saling for your perrin 3" intake using vgi utility to get it correct
SpeedFromSwede (01-06-2015)
Old 01-19-2015, 07:30 PM   #19
SpeedFromSwede
Drives: WRB BRZ
Ok, so I finally got around to logging about 30 mins of closed loop driving using the v2.x oft tunes (with about 150 miles since flash) and the LTFT's haven't gotten any better. Will be plugging this in to VGI and then logging some open loop.
Hopefully this will fix the issue, I can now wipe my finger in my exhaust tip and see fuel. In my mind that isn't good
http://datazap.me/u/speedfromswede/o...log=0&data=1-9
Old 01-19-2015, 09:11 PM   #20
steve99
sometimes it takes a coulpe of goes to get scaling correct if its xway off.
double check for any intake air leaks and especially the little gasket on the maf sensor mount its very easy to pinch or crease it.
i would expect the perrin supplied scaling to maybe be 5% off max but if your seeing 15% i am starting to suspect a hardware problem or air leak ,
Old 01-19-2015, 10:05 PM   #21
SpeedFromSwede
Drives: WRB BRZ
I'm probably going to take it to Mach V near me for their help, but I just don't have time during the week to cooperate with their hours.
I took the MAF out and inspected it all looked fine (clean, good gasket) so I'm not sure what else to do. I don't want to use VGI if my fuel trims are that high and there is potential hardware issue.
Another note is the fuel trims are fine at idle (probably insignificant)
Thanks for all the help, I really appreciate it.
Old 01-20-2015, 05:35 AM   #22
steve99
I would give the vgi utility a go , if you have checked for leaks maybe the perrin scaling is just off by a fair bit. It should be fine with the trims the ecu was running your commanded afr was following your measured afr reasnobly well.
I just thought it was a bit unusual, but the stock maf sensors can vary 8% or more so its likely yours was just different from the maf sensor perrin did their scaling on.
its a worthwhile excercise and good experience to scale maf sensor
Old 01-20-2015, 09:38 AM   #23
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
It is likely your MAF sensor is out of calibration. Mine is and I had to rescale the MAF table. I imagine you could also get a new MAF sensor. The quality control on the MAF sensor for Subaru is not so good. Mine had high positve fuel trims too. Uncorrected I was about 1.0 AFR off from requested.
Toyota John is offline   Reply With Quote
High rev Hempo Engine, Exhaust, Transmission 13 12-23-2014 07:01 PM
How high can i get my rpm in a new car? 10series#1969 Scion FR-S / Toyota 86 GT86 General Forum 11 02-14-2014 02:52 AM
Why is my GoPro battery life so incredibly bad? qoncept Off-Topic Lounge [WARNING: NO POLITICS] 5 05-20-2013 02:43 PM
High Beams DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 01-12-2013 11:44 PM
