Old 12-03-2014, 11:48 PM   #15
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by campy View Post
"One or two" of how many engines?
Honestly, it doesn't sound like this larger blower is worth it for people who are not also doing internals.
Also don't know at what whp/torque they popped at. If the blower was pushing 400+ when it blew or if it blew at minimal boost levels similar to a 210's 70mm setup.
Look forward!
Kiske is offline
Old 12-04-2014, 12:26 AM   #16
s2d4
s2d4's Avatar
Well, one is tuned by toni - it'll pop let alone not using E85.
The other was also tuned by someone of questionable skills, on basically US 91.
These two cases represent the worse case scenarios.
Surely someone decent at tuning (neither of the above) and has common sense (again, neither of the above) to tune with E85 would do a much better job, especially when it appears he'll be doing it systematically?
s2d4 is offline
The Following User Says Thank You to s2d4 For This Useful Post:
Xero-Limit (12-04-2014)
Old 12-12-2014, 01:48 PM   #17
swift996
swift996's Avatar
Originally Posted by moto-mike View Post
5 bucks says you'll get tired of that "vette" quite soon and be back in the fold
I just might down the road (interested in this setup). For now I'm happy with making 600 to the wheels on 93 although it comes in 12mpg
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline
Old 12-12-2014, 07:46 PM   #18
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Today is the big day. I had to run out of town, and the guys were able to finish up the hardware portion so I can come back in tonight and get the base tune in. We started with our base 210 tune, and then obviously turned down the cam timing and ignition timing. To err on the safe side, ethanol was added to get about a 60% mixture. We're running the Deatschwerks 700cc injectors and the DW65c fuel pump with our flex fuel kit.
Starting it up we had some misfire issues on #2 (this car has had it) and after some hard revving we cleared up and went for a drive.
Initial impressions: The Sprintex base (210) kit makes the car act like a strong v6. This kit? Strong v8. Having tuned just about every variant of this car, I'm incredibly pleased with the power and response. With the winter tires on the car 1st-3rd is a spin fest at WOT. 4th was loose, at 4,500 RPM. Yup, that potent. It isn't just the tires though, it has a ton of pull before it breaks them loose.
But we all know a big blower makes big power. More importantly, we're doing this with timing in the teens, on E60, and very rich AFRs. That means we're at a good baseline with plenty to go.
I know most everyone wants to know if this kit will work on pump gas vs e60. I think it will work as well as any other kit. I'd guess we're 12-14 psi or so, but that's 12-14 psi starting at 2500 rpm. Estimated since we don't have a boost source hooked up yet. We'll run down some of the ethanol gradually and watch the knock counts as we dilute it out. Tuning will be 100% the determining factor here IMO, but we've done tons of 14+ psi systems and I don't see any issue with this kit doing it vs another.
We'll keep updating as we rack up the miles and get more findings. The car sees about 18k/year and we even put snows on it so it can remain the DD.
Until then enjoy the media and the glorious sounds from our shorty intake!
[ame="https://www.youtube.com/watch?v=7GY-X11e_nM"]https://www.youtube.com/watch?v=7GY-X11e_nM[/ame]
Xero-Limit is offline
The Following 15 Users Say Thank You to Xero-Limit For This Useful Post:
Chad86 (02-06-2015), Coheed (04-04-2015), Draco_PR23 (12-12-2014), Dream20b (02-21-2016), JonAvalon (12-12-2014), Lawnik (12-12-2014), raven1231 (12-15-2014), rusty959 (12-12-2014), s2d4 (12-14-2014), Stark Performance (12-12-2014), tahdizzle (12-12-2014), Toyota86.ir (03-08-2016), VroomVroom86 (12-12-2014), woode (12-12-2014), wrxgoose (01-17-2015)
Old 12-12-2014, 08:05 PM   #19
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline
Old 12-12-2014, 08:28 PM   #20
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hell yes!
continuecrushing is offline
Old 12-12-2014, 08:34 PM   #21
Stark Performance
Drives: 2014 FR-S
Glorious sound from intake is indeed glorious.
Stark Performance is offline
Old 12-12-2014, 08:58 PM   #22
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Awesome news developing here, I like it. Please keep up the good work.
Lawnik is offline
Old 12-12-2014, 09:18 PM   #23
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I'm liking the torque claims, when can we expect to start seeing some graphs of the new unit? PD blowers tend to have lower peak numbers so it'll be hard to steal the limelight from turbos and centris. I'm curious to see how this progresses.
Whatabouteggs is offline
Old 12-12-2014, 09:30 PM   #24
Xero-Limit
Xero-Limit's Avatar
There have been graphs posted and I don't doubt them for a second. Honestly I'm having a hard time justifying the dyno trip. We know we're detuning, and without building the motor we won't find out the limits. Our one other kit went to a built motor customer so perhaps he will share his findings when it is time. If anyone with a built motor wants to try this experiment (or non built...) there are still a few systems left for the brave.
For our car, it pulls plenty strong up top. I'd have to be in 4th or 5th to be able to redline it currently with any sort of traction in the winter, which just ain't happening on public roads
I'm much more interested in seeing how much timing we can run on both e85 and pump. That will have a much more important figure in the commercial viability of the kit and how many Sprintex sends our way on the next boat.
Old 12-12-2014, 09:37 PM   #25
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm liking the sticker on that intake pipe. Does it only come supplied with the 335 kits?
Fizz is offline
Old 12-12-2014, 10:06 PM   #26
jflogerzi
jflogerzi's Avatar
Does this have an intercooler just like the 210 kit?
jflogerzi is offline
Old 12-12-2014, 10:07 PM   #27
Lawnik
Lawnik's Avatar
@moto-mike
Can you source just the upgrade parts to a 210 I/C kit ? Blower, snout and rear elbow.
Lawnik is offline
Old 12-12-2014, 10:49 PM   #28
Xero-Limit
Xero-Limit's Avatar
Originally Posted by Lawnik View Post
@moto-mike
We can source anything...but that won't make sense for most folks. You can buy a new 335 kit for a bit over 5 and get it in a week, sell your old one for at least 3000-3500, and you're out 1500 while getting a new blower. A 335 by itself will cost you over that, and the old 210 really carries very little resale by itself.
We can get it, but you'd have to pay and wait a couple of months until the parts ship from down under.
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
