Old 11-17-2014, 11:00 PM   #15
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by carma143 View Post
I was testing if there were better ways to accelerate from a standstill than feathering the clutch, because it ever so slightly wears out several components.
Maybe it's me being overly sensitive, but it sounds like you already have some sort of grudge towards me.
Alright, that makes more sense. You should be able to rev it up to 2-3000 and feather it out VERY quickly, but not popping it. From the time the clutch starts grabbing to the time it's fully engaged and you can mash the throttle should be half a second. That will give you a very abrupt, but relatively smooth take-off.
It sounds like what you need to do is go to an empty road or parking lot and just practice this over and over and over until you can do it smoothly. It isn't hard once you get the hang of it. Some people just have more trouble coordinating their left and right feet for this thing than others. As someone else suggested, it might be a good idea to recruit a friend who drives stick to critique you and tell you what you need to do differently.
Sorry if I was a bit bitchy in my initial post. It really sounded to me like you just were being lazy about it the way you had worded it.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
JohnJuan (11-18-2014)
Old 11-17-2014, 11:58 PM   #16
Wafflejuice
Drives: '15 WRB BRZ Aozora
This.
When I first got my car, I tried to take off at 1000rpm. Ended up stalling more than anything. 2500-3000. No problems. Still jerky at times though, I think I let out the clutch too fast..
Wafflejuice is offline   Reply With Quote
Old 11-18-2014, 12:15 AM   #17
Fastbrew
Drives: 2014 Pearl White BRZ
Also as Stang said - a quick blip of the throttle and then a fast but controlled release gets it moving well. I like to blip to 4K, let it come down to 3K then dump the clutch and put the hammer down.
Fastbrew is offline   Reply With Quote
Old 11-18-2014, 10:11 AM   #18
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
That's why a clutch is called a wear component. It's supposed to allow slight slippage for smooth engagement/acceleration. This is essentially what a TQ converter does in an automatic. If you don't slip the clutch, you shock the other parts more, which are not wear components.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 11-18-2014, 11:36 AM   #19
Koa
Dumping the clutch at 3k every launch hmm
These cars are able to be rolled on by a blip to 2k or so and catching it on the down, rolling on the gas...
Old 11-18-2014, 11:57 AM   #20
stonenewt
Drives: BMW 120d
Manual pulling away basic principle
- engage 1st gear with the handbrake on.
- lift the clutch slowly until you can just feel the car starting to pull against the handbrake
- release handbrake
- immediately feed in the throttle & slowly feed out the clutch
this will keep the clutch slip to a minimum & allow you to pull away reasonably briskly. It's a little more difficult on the BRZ because the clutch is slightly funky for feel & bite position. But even with nerve damage in my left leg so it doesn't move properly/as expected I can pull away with the minimum of fuss.
For a faster normal start give your self about 1500-1750 rpm & pre-empt the bite point with the handbrake release.
For a very quick straight launch bring the revs to a stable 4k rpm. The release handbrake, slam your right foot flat too the floor & jump off the clutch at the same time. Racing launch (this is brutal kiddies and will break your car if the tyres don't slip!) is the same except you delay the clutch a fraction & then side step it
These latter two shift the slip wear from clutch to the tyres but they also put much more stress on the drive train mounting system as well as the 'box & diff' internals.
stonenewt is offline   Reply With Quote
Old 11-18-2014, 12:35 PM   #21
Koa
- release handbrake
No offense mate but using the handbrake at all is bad practice and recommending that to newbies is a surefire way for them to develop bad habits.
Teach them about the clutch biting point instead
Old 11-18-2014, 12:37 PM   #22
Koa
Here's an excerpt from an earlier post of mine
The hand-brake method of stopping (and conversely starting) on a hill can be completely done without if you practice feeling out what is called the clutch biting point. This is the point in which the clutch begins to become engaged.
Tutorial 1 - Master feeling out the biting point
1. Find a hill that is not too steep and in an area where you can be stopped upon for long periods of time.
2. Position and stop the car on the hill using your foot brake.
3. With your clutch pedal pressed in, put the car in first gear while holding the car with your foot brake.
4. WITHOUT RELEASING YOUR FOOT BRAKE, slowly begin releasing the clutch pedal until you start to feel the clutch 'biting'- you'll feel the RPMs drop as if you're about to kill it and feel the drivetrain tensing up. Push the clutch pedal in after you find this point.
5. Repeat step 4 until you are confident of your feeling for the biting point.
Tutorial 2 - Getting comfortable with using the clutch biting point to prevent the car from rolling backwards on an incline
Before you begin, make sure you are comfortable with being able to feel and bite the clutch.
1. Position and stop the car on a hill with your foot on the brake, in first gear, with the clutch pedal pressed in.
2. Let the clutch out just enough to get to the biting point, but not far enough to where the RPMs begin to drop
3. Release the foot brake. If done right, you'll still be stopped and not sliding backwards.
4.Rinse and repeat until comfortable
Hope this helps
Old 11-18-2014, 12:39 PM   #23
stonenewt
Drives: BMW 120d
So everyone taught to drive in the UK is being taught to do it wrong?
There are several good reasons to use the handbrake, the most noticeable of which is to prevent the car from rolling in an uncontrolled manner.
EDIT: You've just posted how to fail your UK driving test in one east step!
Old 11-18-2014, 12:42 PM   #24
Koa
See my above post. I've been driving manuals all my life and never had to use one. Best practices is to get comfortable without it. Being familiar with the clutch biting point is essential to never having to worry about rolling back on a hill start.
I live in Seattle, Washington with nothing but hills and Prius autos zooming right up to your bumper at stop lights.
P.S give me a brake ( ), it's not rocket science to use the handbrake on a hill in your silly UK driving test. Funky euros.
Old 11-18-2014, 12:44 PM   #25
stonenewt
Drives: BMW 120d
Yeah it's a fast track to fail your UK driving test!
Old 11-18-2014, 12:45 PM   #26
Koa
whatever crutch helps you drive is fine. Just trying to show those there are easier, more predictable ways without depending on another system to keep them from rolling backwards.
Old 11-18-2014, 12:51 PM   #27
stonenewt
Drives: BMW 120d
The difference between the foot brake and hand brake method is the predictability & reliability of the handbrake method which is not subject to as many coordination problems or forward rolling.
Old 11-18-2014, 12:57 PM   #28
Koa
The difference between the foot brake and hand brake method is the predictability & reliability of the foot brake method which is not subject to as many coordination problems or forward rolling.
I agree, the clutch bite/footbrake method is indeed more predictable and reliable than trying to work the handbrake system as well as your foot pedals.
The Following User Says Thank You to Koa For This Useful Post:
stugray (11-18-2014)
dead pedal, octane, response, slow
FRS auto -slow acceleration at 70km/hr Zhangy Scion FR-S / Toyota 86 GT86 General Forum 9 11-12-2014 01:33 AM
Slow Revving / Acceleration after TSB 0040-13 Hardway Issues | Warranty | Recalls / TSB 9 08-25-2014 11:14 AM
Acceleration Times itdansharpe Engine, Exhaust, Transmission 8 06-09-2013 05:25 PM
Not disappointed but curious. Why BRZ's acceleration numbers are relatively slow? Wait4BRZ_STI? BRZ First-Gen (2012+) — General Topics 46 04-10-2012 11:46 PM
Acceleration Axel Other Vehicles & General Automotive Discussions 0 02-10-2010 07:56 PM
