Old 11-07-2014, 07:23 PM   #15
wheelhaus
wheelhaus's Avatar
I wouldn't rule out the brakes or transmission, both are still turning when the car is rolling. In neutral, the only part of the transmission that slows down is the input shaft/intermediate shaft, but if the rear wheels are moving, so are all the gears.
If it's a dry scraping/rubbing sort of chuffing sound, something might be rubbing a tire or rotor, or the drive shaft. Approx how many "chuffs" per second at 20mph?
It might be as simple as a stick or brush caught under the car somewhere...
wheelhaus is offline   Reply With Quote
Old 11-07-2014, 09:15 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Reaper View Post
Nope. No lsd. Torsen.
Who pissed in your corn flakes today? Go take a time-out.
Old 11-07-2014, 09:25 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This car does not have an LSD.
Are you on stock suspension? Is it the driveshaft carrier bearing? When I first lowered it the toe was out enough to make some road noise on my way to get an alignment.
why do you own this car? what makes you think it doesn't?
Old 11-07-2014, 09:33 PM   #18
lo_Opy
lo_Opy's Avatar
Drives: 2013 Subaru Brz WRB Limited
Can you record it somehow? I'm experiencing, what seems like the same problem.
lo_Opy is offline   Reply With Quote
Old 11-25-2014, 11:49 AM   #19
FRiSson
Drives: FR-S MT
Okay, problem solved! It was the tires -
I changed over to winter tires and the sound is GONE!
The OEM tires are fairly worn, so I'll just replace them in the Spring.
FRiSson is offline   Reply With Quote
Old 11-25-2014, 12:03 PM   #20
wheelhaus
wheelhaus's Avatar
Could you see any scuff marks or debris that might have been causing the sound? It's a little weird that the tire itself would make noise other than tread/road noise.
Old 11-25-2014, 12:09 PM   #21
FRiSson
Drives: FR-S MT
No marks or debris. It may be something internal in the tire. I also didn't see any marks from misalignment or over/under inflation.
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
Very annoying rattle/noise in the back of my BRZ. Any help? MrGamer BRZ First-Gen (2012+) — General Topics 6 08-02-2013 09:32 AM
weird plastic squeaking noise (back seats) whyreeto AUSTRALIA 5 09-17-2012 01:34 AM
