#15 |
Drives: GT86 Cosworth
TMG list the oil cooler as optional. I this running a thicker oil is the way forward. TRD japan also recommend a heavier oil.
Cirtainly a 10W60 will keep pressures up!! It might be okay for me to use a 10W40 as my car is garaged and generally comes out with oil temps greater than 0C. The oil pump is fixed flow (except when pressure relief is open). Pressure is determined by resistance in the system. More resistant (for example smaller bearing clearances) with give more pressure but the pump will guarantee flow unless the relief valve is active. |
#16 |
Drives: 2014 GT86
offtopic
@bur****jp: thanks for linked doc. I noticed many interesting bits in that document. Like race ecu update, Thermostat opening temps, diff final gear ratios, diff oil cooler, custom headers & twin pipe catalysator exhaust system which is homologized (wonder if it's street legal on stock twins?), lightweight windows, billstein shocks, specific rollbars/struts and so on .. wondering if something from that can be ordered/fitted on our cars especially exhaust system/ecu.. |
#17 | |
#18 |
Because compromise ®
Drives: Red Herring
Is there a trade off with doing this? Too high a pressure when cold?
#19 |
Yes!
Pressures are quite high cold as it is really. At 100C on 0w20 it gives a perfect 10psi/1k so thicker oil is too a compromise.... |
| The Following User Says Thank You to ajc209 For This Useful Post: | rice_classic (05-04-2015) |
#20 | |
Drives: Nevermorange FRS
A small shim (small pressure bump) and a 0w-30 may be an excellent compromise for double duty (track/DD) car. But shim or no shim, it's always, ALWAYS, best to let your car warm up before you rev it high or drive it hard.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | DustinS (05-04-2015) |
#21 |
Drives: 2013 Ultramarine FR-S
Things just keep getting interesting in the oil department.
I am interested how everyone is getting the oil so hot. I can drive around spirited in 80F and only hit 180F oil temp. I am seeing people hit 220F on their drive to work. What I am reading is to bump to 0w-30, shim the pump, and watch temps/psi. Sound correct?
#22 | |
Turning is for Nerds
Drives: 35 characters is not enough
| The Following User Says Thank You to Decay107 For This Useful Post: | rice_classic (05-05-2015) |
#23 |
Subaru Ambassador
Drives: 13 BRZ 18 Silverado
My car is a track car only. No oil cooler and it has been on track since it was 70 miles old. Currently has header, no cats and a Borla exhaust, intake, tune, suspension, all the usual sutff. Running 0-40 Castrol Edge I can guarantee that the oil will be between 248-257º, depending on ambient temp. Other BRZ/FRS guys see higher temps than I do, I have been doing this for a long time, I am not kind to my car. Oil pressure never drops below 50 psi. Will I spin a bearing eventually? Probably, but the car has 14,xxx miles so far and I just doesn't seem to care what I do to it. I might go up a grade on the next oil change to see what happens. I personally don't think doing 20 minute DE sessions under these conditions is doing much harm. Racing would be a different story.
#24 |
I plan on 2-3 track days this year, Auto-X (once I get weekends off), and many spirited "Canyon" Runs.
#25 | |
Drives: bmw
the data is from multiple track events, i will note the above cruising on the highway i can get there, even with this oil cooler (vid in link)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#26 |
I actually found that my oil temp gauge(tapped into the galley plug) read anywhere from 20°-48°F cooler than my OFT reports. I cruise at 210°
| The Following User Says Thank You to DustinS For This Useful Post: | flippy (05-15-2022) |
| VIDEO - Install guide for OEM style coolant loop Oil cooler. | The Sentinel | DIY (Do-It-Yourself) Guides | 44 | 10-15-2018 08:42 AM |
| DIY Cusco Spin Turn Knob Installation - Video Guide | Alex | DIY (Do-It-Yourself) Guides | 25 | 08-02-2015 03:03 PM |
| Video guide - Installing BlackVue DR550GW-2CH and T-Power C UPS | The Sentinel | DIY (Do-It-Yourself) Guides | 8 | 02-11-2015 11:09 PM |
| Plot your oil pressure vs temperature | Gords_zenith | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-22-2014 06:09 PM |
| DIY 6000K HID Kit Installation(Scion FR-S ONLY) - Video Guide | Alex | DIY (Do-It-Yourself) Guides | 10 | 07-09-2013 07:38 AM |
