Old 10-18-2014, 02:06 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Update: There's more going on. The really loud "clack" that sounded like metal on glass is gone but I'm not satisfied with the results. Still makes a little bit of a "click" after it's been sitting closed for a while. Meanwhile the passenger side window works perfectly.
Going back in today for another look. Apologies for my initial exuberance.
Old 10-21-2014, 05:10 PM   #16
frs10
Drives: tezla
wow that sounds really bad in those vids, cant wait to see what you come up with!
frs10 is offline   Reply With Quote
Old 10-21-2014, 06:07 PM   #17
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Originally Posted by frs10 View Post
my window is making a strange sound and was wondering if anyone knows how to check if the window is off the track without taking the door apart? is anyone else having this issue?
My drivers window was so off track it etched the glass. Had it replaced under warranty. It happened again and they found out the original track guide was bad.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 10-22-2014, 12:11 AM   #18
Ultramaroon
not playing cards
Heh, I think the sound was exaggerated because it was so quiet. That's just the normal click of first the latch and then the window hard-stop. We're talking about something which, after sitting under the residual stress of normal closure, binds up. When reversed, it lets go with a "clack" almost like tapping the window with a stone.
Update: There was more wrong with the entire assembly alignment than actually correct. It's almost as if the components were slapped together without any alignment or more likely, they were aligned to a poorly-matched jig. I don't know how they do it in production.
Root cause appears to be accelerated wear due to a combination of water intrusion and misalignment. This water intrusion is the same that is addressed by the Frozen Window TSB. The Subaru document is better and there is also this one which admits the initial door strip is a POS.
I haven't yet disassembled the guts but I will purchase the parts and perform this correction myself. Stopping by the dealer tomorrow.
Stay tuned.
Credit to @Sigh-on-Rice for collecting these service documents. Thank you, sir!
Old 10-22-2014, 12:32 AM   #19
Ultramaroon
not playing cards
Curious, what parts did they replace? I can easily see the window scratching from a misaligned track.
Old 10-22-2014, 02:24 AM   #20
Ultramaroon
not playing cards
the same sound it makes when you open or close the door and the window goes up/down except really loud with a ehhh noise
BTW...
[ame]http://youtu.be/XiT_5cr3tYI[/ame]
Old 10-22-2014, 12:06 PM   #21
frs10
Drives: tezla
wow great findings! keep us updated!
Old 10-23-2014, 10:30 AM   #22
hur1ey02
hur1ey02's Avatar
Just FYI in case it helps, there was an update to an internal stabilizer in the windows. Mine had scratches and issues with noise when wet - they replaced the stabilizers with the new style (my car is a 2013) and it has helped tremendously.
That might help!
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 10-23-2014, 02:14 PM   #23
Ultramaroon
not playing cards
That might help!
Those are on my shopping list I sorta jacked @frs10's thread for now but am working towards what is turning out to be a doozy of a DIY. It won't be for the faint-of-heart because window alignment is about as tricky as hanging the door itself. Thanks for your input!
Old 10-30-2014, 01:13 PM   #24
frs10
Drives: tezla
no problem brother keep the info coming!!
The Following User Says Thank You to frs10 For This Useful Post:
Ultramaroon (10-30-2014)
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 08:25 AM
Window Air Leak After Frozen Window TSB Fix Luckrider Issues | Warranty | Recalls / TSB 6 04-27-2014 07:24 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 06:34 AM
Stock intake tract flow testing? zooki Engine, Exhaust, Transmission 1 01-24-2013 11:34 PM
