Old 10-08-2014, 02:34 PM   #15
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by 636 View Post
Just go to autozone and buy a plug, do it yourself. Takes no time at all.
I've plugged my car's tire twice, and my motorcycle like three times, and they all held up great.
...even at 170mph.
You win! - Absoulte WORST advice possible.
The Following 3 Users Say Thank You to stugray For This Useful Post:
53Driver (10-08-2014), shiro (10-08-2014), wparsons (10-08-2014)
Old 10-08-2014, 02:43 PM   #16
636
636's Avatar
Drives: '23 CWP BRZ
lol that's funny. Properly plugged tires are not dangerous whatsoever.
636 is offline   Reply With Quote
Old 10-08-2014, 02:51 PM   #17
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
We may need to see few more extra pics OP, just to make a solid judgment.
Old 10-08-2014, 02:59 PM   #18
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
LOL tire repair.
Problem is you do not know exactly how the tire's been compromised. If it's severed a cord or merely went between them. How many cords were severed, or how much load those cords bear. While sure, you may plug the tire and it may be okay, you're still taking a risk that the tire will fail while driving.
The only 100% sure way to know that a tire will hold up (barring any issues from defects) is to get a new tire. Since it's rather new, you should only need to replace one tire instead of both L/R tires, but that also depends on the treadwear of the opposite tire.
Your call OP. My advice is to just get a new tire/tires, then get road hazard warranty on said tire/tires so you never have to worry about this stuff again.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
The Following User Says Thank You to aznatama For This Useful Post:
Old 10-08-2014, 03:04 PM   #19
DarkSunrise
DarkSunrise's Avatar
I see these are NT05's. Do you plan to track or autocross with these tires at all??
Even if technically repairable, I would not track on a tire that had been punctured on the outer tread block like that. That's usually the part of the tread where chunking occurs. If the repaired part of the tire chunked or gave out as you were loaded up in a corner, and you suddenly lost all tire pressure, you could be in real trouble.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 10-08-2014, 03:09 PM   #20
s2d4
s2d4's Avatar
Can you tell us why?
Old 10-08-2014, 03:09 PM   #21
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
WHO's the Mark?
The very link that you post shows that the OPs puncture is OUTSIDE the "tread area" and in the "Shoulder".
From the very site you linked to:
And from Tire rack:
http://www.tirerack.com/tires/tirete...jsp?techid=187
"Repair of any punctures in the shoulder and sidewall areas is not permitted."
"This tire has been punctured through the shoulder area long enough ago for part of the nail head to have worn away. Since the puncture is outside the permitted repair area, this tire must be replaced."
AND the fact that the bolt in the OPs tire appears to be at least a 1/4", then it cannot be repaired "By industry guidelines".
"Guidelines allow the repair of punctures in a tire's tread area of up to 1/4" in diameter. Repair of larger tread punctures and of punctures to the tire's shoulder and sidewall areas are not recommended."
So based on the above, I would say that the tire repair place will NOT repair that puncture, especially if it is a speed rated tire AND the fact that the OP drove on it like that.
@jsimon7777
boooooooooooooooooost
Ammonia is offline   Reply With Quote
Old 10-08-2014, 03:13 PM   #22
stugray
What's funny is that your suggestion is in no way a "properly plugged tire".
For a tire to be "properly repaired" it must be demounted. Period.
What you suggest is just for side of the road repairs to get you to a tire shop.
Old 10-08-2014, 03:21 PM   #23
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Originally Posted by jsimon7777 View Post
53Driver, don't be a mark. There are no laws about 2". Total lies you've been fed.
http://www.rma.org/tire-safety/tire-repair/
Repairs are for the tread area only. You're within the tread area. You can see the line in the rubber. That screw looks to be less than 1/4" in diamter. Not big at all. Go to America's Tires. They'll probably fix it right, and possibly for free. Nitto even has guidelines about the tire's speed rating after repair. You'll be sad to know that your tires will likely only be good for 130mph.
Considering three different reputable tire businesses gave me the same answer, I'm inclined to believe them. Was it frustrating that I had to replace 3 tires in a 4 month period? Yes it was. However, if you can't afford a new tire then you can't afford this car not to mention the safety concerns for yourself and others on the road should you decide to drive on a questionable tire that isn't replaced or repaired properly.
53Driver is offline   Reply With Quote
Old 10-08-2014, 03:22 PM   #24
53Driver
53Driver's Avatar
Because he did it and nothing bad happened to him?
Yet.
Old 10-08-2014, 03:33 PM   #25
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by Ammonia View Post
I've had stug on ignore for over a year.
Old 10-08-2014, 03:38 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Certainly you could have had severely damaged tires, but the law and 2 inch rule are make-believe.
Tires have been patched for quite a long time. I might not track on patched tires, but for the road they're fine ad long as the structure isn't compromised. Those DRM rules look pretty darn conservative and yet his screw is within the main tread so it's fine on that count.
Old 10-08-2014, 03:38 PM   #27
Ammonia
Ammonia's Avatar
Oh okay. Was waiting to your rebuttal of his post because he picked apart your argument pretty fast lol
Old 10-08-2014, 03:39 PM   #28
stugray
His loss....
Guess he hates to be proven wrong.
And I have two sons that work at different tire shops.
The Following User Says Thank You to stugray For This Useful Post:
Ammonia (10-08-2014)
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
Tire for 250 whp kaybee123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 02-15-2014 09:04 PM
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
