Old 07-16-2012, 05:21 AM   #15
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Cheers for the info Sam......
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-16-2012, 06:59 AM   #16
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
+1 Outstanding post.
Apex Chase is offline   Reply With Quote
Old 07-16-2012, 07:41 AM   #17
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
Originally Posted by fatoni View Post
the reduction in lap times from spending 1.5k more on shock is not as big as the reduction in lap time from spending 1.5k on track time
mod the driver...
like Sam stated your dampener is the performance link and i totally agree. the reason the high end suspension makers "allow" you to choose a spring. i havn't chosen my springs yet but have decided on JRZ dampeners. my shocks alone are gonna run more than what some ppl will pay for coils. i wasted so much money on bolt-ons in the past before i got smart and worried about fixing myself and learning why certain parts had certain effects.
my particular goals with this car are all related to personal improvement. so my path is pads, ss lines, fluids, bushings, then shocks/springs, then tires, then sways. that's it. don't need power upgrades to makeup for slow corner exit right now. in my opinion that's the optimal path for driver development in this car the way it was engineered and delivered. i can't quantify how much faster taking small steps adds up. and how much chasing power will slow most ppl down in the long run. even the autox guys i would advise to run the stock suspension until they are 100% at the limit. it's that good guys. learn the car before you change too much on it and can't keep up. i learn more everyday about this stuff and just how much greater suspension changes effect the car and driver than power changes do.
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 09-11-2012, 04:43 PM   #18
nightfire
Drives: 2013 SWP BRZ Limited manual
Question
Do you have a link to the JRZ dampers? I can't find any dampers for the BRZ on their site or anywhere on the web.
Originally Posted by BadCompany235 View Post
mod the driver...
And which of these companies make dampers which are compatible with lowering springs? Seems like most are only made to run with the stock springs.
nightfire is offline   Reply With Quote
Old 09-11-2012, 05:09 PM   #19
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Sam Strano View Post
I will tell you flat out that a set of Koni Sports (which are coming if you can be patient) and a nice set of lowering springs (not all are equal there, and some names you "know" tend to be some of the more sucky stuff) will be better than an el-cheapo set of "coil-overs".
any update on this?
Old 09-12-2012, 10:03 AM   #20
Here's our write-up for the JRZ RS1 coilovers:
http://www.ft86club.com/forums/showthread.php?t=11759
We also have a thread in the vendor section.
You won't see them on their website, but we are just up the road from their east coast HQ and have them available now.
- Andrew
Old 09-12-2012, 10:20 AM   #21
nightfire
Question
- Andrew
Ah I assumed that JRZ made just shocks instead of full coilovers.
Anyone know of some performance shocks to match with lowered springs? Someone HAS to make them..right?...
Old 09-12-2012, 10:46 AM   #22
Nothing yet.
Koni will probably first. Bilstein will have something eventually.
- Andrew
Old 09-12-2012, 10:57 AM   #23
nightfire
Hmm ok. Doesn't Koni usually come out with shocks that are for stock springs and not lowering springs? Seems risky for the guys that are using lowering springs without a backup shock for one the stock shocks when they go..
Old 09-12-2012, 11:08 AM   #24
Koni Yellows can definitely handle some spring rate over stock. Not gonna be great with a huge drop, but you shouldn't do that anyway if you care about handling.
- Andrew
Old 09-12-2012, 12:47 PM   #25
nightfire
Definitely not looking for a huge drop. Just something that handles well and is maybe a 1" drop. I guess I'll just have to hold off till someone makes shocks.
Old 09-12-2012, 12:54 PM   #26
The stock shocks aren't that bad at all. They work really well at least with our RCE Yellows.
- Andrew
Old 09-12-2012, 02:04 PM   #27
nightfire
How are the wear rates with the stock shocks? The extra compression from the lower springs would increase shock wear I assume? A lot of people on the forums seem to be just watching and waiting to see how long they last
- Andrew
Old 09-12-2012, 02:10 PM   #28
gmookher
sorry if its posted what are the rastes on the yellows?
gmookher is offline   Reply With Quote
Coilovers? trueno86power Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 05-29-2012 05:20 PM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
BRZ Shocks dynoplot! OrbitalEllipses Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 04-24-2012 01:16 PM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
