Old 02-03-2015, 05:02 PM   #15
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I would just go along with what's scheduled in the owner's manual.
For me, I go to drift days and stuff fairly often so I just do an oil change every 3,000 miles or so (usually do 1 or 2 events in that time frame) and change the diff and transmission fluid every other time I change engine oil (around 5,000 miles).
Some might say that's too often; some might say it's not often enough. It's what I've done with all my vehicles I tracked though and I've yet to ever have an issue that would make me reconsider what I've been doing.
TylerLieberman is offline   Reply With Quote
Old 02-03-2015, 06:05 PM   #16
Max FRS
Drives: 2015 Halo FRS Automatic
My 2015 warranty and maintenance guide page 37 state 7500 miles for oil changes. Where are you seeing 6000?
Max FRS is offline   Reply With Quote
Old 02-03-2015, 06:20 PM   #17
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
Originally Posted by JGalp View Post
Hey guys, (FYI I live in Southern CALI, warm weather all the time)
I just bought a 2015 BRZ limited and i need some help. Ive been searching the forums for advice on break in, when to change what oil, with what kind of oil, etc..but the advice is all over the place.
I just went over 1000 miles and i followed break in procedure recommend by subaru with slight twists. i never drove her hard cold, never went over about 5500 RPM and i constantly varied speed while on freeway. So far she shifts like butter no problems at all, however i have developed the chirping at idle
Now for a few questions:
1. When should i change the oil and with what brand oil/filter? I've heard a lot of people say 500, 1000 3500, and 7500. the different ar guements about changing it out right away, other people saying that the break in oil has special additives that you wanna keep in until 3500 miles.. Any advice on this would be great.
2. What about the other fluids? MTF, Diff? when should i change them and with what brand? Ive heard a lot about MOTUL, but for the transmission i heard its super thick (mostly from guys that live in colder climates) however it heard its fine for guys living in warmer climates (like me) I've also heard about Pentosin MTF 2 or something which I'm also considering going with. What do you guys think? and when should i change it out?
3. Any other advice that a new owner should know about regarding maintenance would be greatly appreciate!! Anything at all please don't hesitate to chime in, things like should i get a fumoto oil drain valve.. is it beneficial? even if I'm not changing my own oil? (ill most likely be taking it to evasive motorsport or fusion teknique for all my services)
Thanks guys, Much appreciated!
John
http://www.ft86club.com/forums/showthread.php?t=18384 heres your chirping issues. welcome to the club!
Eski is offline   Reply With Quote
Old 02-04-2015, 08:56 AM   #18
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
You may have an early production car. All the subies have dropped from 7500 to 6000 for MY2015.
Similar issue was in the owners manuals in the MY2011s when they went from 3000 to 5000.
-mike
AZP Installs is offline   Reply With Quote
Old 02-04-2015, 11:15 AM   #19
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by GotMunchies? View Post
1. Follow factory service guide for oil change interval. (7,500 miles was changed to 6,000 miles for MY2015. You decide.) Choose any big name 0W-20 full synthetic oil and the Subaru OEM Filter. I'm putting 0W-20 Mobil 1 Advanced Fuel Economy because it was on sale, meets my use-case and a Subaru filter because its reasonably priced and perfectly functional. I'm going with a 5,000 mile change interval because... its a nice a round number. I run my diesel Golf at 10,000 mile intervals because that's what's recommended and it sees lots of highway miles. Exciting stuff, I know.
2. Change at factory service interval (30,000 miles for transmission and diff). Use OEM or name-brand synthetics that meet Subaru's required standards (in manual). Consider changing to a better quality oil (e.g. Pentosin or Motul Gear 300) if your transmission starts to get excessively notchy or grinds on shifts.
3. Usual stuff: regularly check your oil, coolant, and brake fluid levels and tire pressure. Don't be late on oil or filter changes. Pop your hood at least once month and have a look around, get familiar with the car. I got a Fumoto valve (going on this weekend) because I do my own maintenance. Completely optional. People who have them, love them.
EXCEPTION: Regularly driving the car in a performance environment (e.g. many autocrosses or regular track days). Decrease change interval and invest in oils for this express purpose. Your occasional spirited run up and down a canyon road or the occasional auto cross does not meet this use-case.
Final advice: Enjoy the car, follow the maintenance schedule (PLAN AHEAD, BE ON TIME), and don't work yourself into a tizzy every time you read something on the internet.
Got a link to that? Neither my manual nor any twin manual I've read, lay out an interval for drive line oils.
Decay107 is offline   Reply With Quote
Old 02-04-2015, 12:04 PM   #20
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
Right you are, there is no stated change interval for the transmission fluid from Subaru or Toyota. However, if one is driving the car in a "spirited" fashion I would still recommend swapping the fluid every 30,000 miles or whenever shifting becomes more difficult than normal - this would be conservative preventative maintenance based on personal experience. But since Subaru believes this to be a "lifetime" fill, that decision is up to the owner.
Cheers!
GotMunchies? is offline   Reply With Quote
The Following User Says Thank You to GotMunchies? For This Useful Post:
Decay107 (02-04-2015)
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 04:07 AM
Going for maintenance with coilovers on ang31ito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-13-2014 07:33 AM
25,000 Where can I go for maintenance. laley81 Southern California 9 09-20-2013 04:00 AM
Maintenance Oil for Turbo? Scalzo Forced Induction 8 05-21-2013 08:00 AM
