Old 05-18-2013, 01:00 PM   #1
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Maintenance Oil for Turbo?
Hey,
I just got an oil change from toyota *Free*
I'm getting the FA20CLUB turbo kit in a few weeks and I want to have everything ready to go,
Do I have to change the oil in my car after I go turbo?
I've heard for the tranny this is good;
Tranny: Motul Gear 300 75W90
what about for the engine and the diff?
Scalzo is offline   Reply With Quote
Old 05-18-2013, 01:26 PM   #2
2forme
Use an oil that holds up to heat well. In the past I've used shell rotella and amsoil on turbos with success.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Pete (05-18-2013), Scalzo (05-18-2013)
Old 05-18-2013, 01:38 PM   #3
Scalzo
Scalzo's Avatar
i'm in montreal so, hottest it gets is maybe 30 degrees celsius ,
But i'm asking, same oils as if i was going N/A
The Following User Says Thank You to Scalzo For This Useful Post:
2forme (05-18-2013)
Old 05-18-2013, 02:05 PM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
I've used rotella on turbo applications as well. Easy to find and relatively cheap.
The Following 2 Users Say Thank You to DJCarbine For This Useful Post:
2forme (05-18-2013), Scalzo (05-18-2013)
Old 05-18-2013, 03:08 PM   #5
2forme
I use amsoil in the BRZ and I'm not turboed
Old 05-19-2013, 01:59 AM   #6
Fast_Freddy
Drives: Passat
Any full synthetic will do, pick your favorite brand in 0w30 or heavier. 0w20 is too thin for heavy duty use.
Fast_Freddy is offline   Reply With Quote
Old 05-20-2013, 09:05 PM   #7
Scalzo
Scalzo's Avatar
I think i'm gonna use 0w30..
Another thing,
Should i be getting any engine mounts or whiteline products ? I see a lot of people getting them?
Old 05-21-2013, 02:59 AM   #8
Fast_Freddy
Drives: Passat
Another thing,
I put a solid poly front engine mount on my boosted XB2 and hated it. The company then offered a much softer bushing and it still sucked. Personally I'd consider trying some inserts but leave the solid engine and trans mounts for full race cars and those who like all that NVH. FWIW.
Old 05-21-2013, 09:00 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It depends on your power goals. Do you plan to be at over 275 whp and over 230 wtq?
If yes, you will need mounts sooner rather than later. Get Perrin mounts, they do not add that much NVH, but it is noticeable how they hold the engine in place.
Maintenance Required? Dan86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 01-23-2013 02:58 PM
Maintenance Plan? ngabdala BRZ First-Gen (2012+) — General Topics 11 08-11-2012 06:39 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 08:47 PM
alcantara maintenance. wallace03 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 07-07-2012 09:49 AM
AMT, Air Maintenance Technology 1660 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-28-2011 04:15 AM
