#15 |
Did you try powering your camera from the beatsonic harness?
I'm not familiar with that particular harness, but I'm assuming there is a +12V output on the harness. You must use that. From what you've said, it sounds like the problem is that you are powering from another source. The headunit does a check when you first turn the car on. It will momentarily turn on the camera's power pin to see if anything is connected. If you connect it to the backup lights, then the camera won't be on during the check(and therefore it won't be recognized). I have not tried mine connected to ACC power but you don't want that because it tends to wear out the camera pretty fast. I will tell you that the relay harness that I bought functions as you would expect(The reverse camera will come on in reverse regardless of the configuration when I started the car).
Garage:
2013 BRZ Limited 6MT - Galaxy Blue 1994 Ford Probe GT 5MT - Red(some would argue pink) 1969 Mustang Fastback 4MT - Royal Maroon |
#16 |
Drives: 2014 Scion FR-S
Thanks for all the help. I finally had time to pull apart the trim to see all the wiring and discovered that the guy who was helping me install the first time around had been powering the camera from the reverse light all along.
Solved the problem now and everything works as it should. Thanks again. |
| The Following User Says Thank You to mike7792 For This Useful Post: | NIN69 (09-29-2014) |
#17 | |
Drives: 2015 BRZ Ltd 6MT
Reviving a Necro-thread
Are you using the autoharnesshouse relay? From my understanding, you disconnect your 16-pin parking brake, and connect it back into the harness, but from the pictures, it looks like it's missing that 16-pin "reconnect". |
| DIY Beat-Sonic Backup Cam Install (FRS) | Techfl3x | DIY (Do-It-Yourself) Guides | 26 | 07-22-2015 03:30 PM |
| Beat-Sonic FR-S Photos | Beat-Sonic | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 46 | 08-29-2013 11:35 AM |
| Beat-sonic JDM shark fin antenna install. | jadewbj | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-23-2013 02:12 AM |
