Old 01-26-2015, 03:23 PM   #15
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Philly758 View Post
I installed a steel pulley a long time ago and I'm not sure if it helped the squeaking. Hopefully this works. It's pretty embarassing.
Just before my first belt failure, it would intermittently squeak especially while cold.
Hopefully a belt swap fixes it, if not then other suspect things would be alignment or the tensioner
2013 FRS
Vortech V3 11psi
Old 01-26-2015, 11:33 PM   #16
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by DJCarbine View Post
In my case it wasn't a matter of which one to like, as the plastic one failed and the steel is easily found at most parts stores
Did the steel pulley give you problems?
Here in phx the thing retained heat moreso than plastic
Belt runs cooler with less steel to run over, plastic also seemed to allow belts to last longer, indeed possibly at the expense of the pulley life, but I rather get in there less often and change both, as they say ymmv
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-29-2015, 01:45 PM   #17
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Did anyone figure out the problem? I've replaced my belt every 3 months (Gates) due to squealing. The most recent time we went with a smaller belt and figured if this one squeals it could be the tensioner. Well sure enough 3 months later it is squealing.
Any help would be appreciated, I realize this is an old thread.
Thanks
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 06-29-2015, 02:42 PM   #18
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Thanks
Try Johnsons Baby Powder.
Sprinkle onto both sides of the belt while idling with the aircon off.
Repeat every few weeks as necessary.
Works for me, and I've been doing it for about a year now.
Just makes a bit of a mess - looks like I spilt my cocain stash under the hood.
Fish Eagle is offline   Reply With Quote
Old 05-05-2016, 02:16 PM   #19
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I have the same issue - Vortech Supercharged, and I have a squeak from the belt area that comes and goes, sometimes it's at idle, sometimes it's at 2.5 - 3k. I changed it last year, squeak went away. Been getting worse now all spring.
I've only used the Gates Blue K060975RB since I went FI two years ago.
At $50 - $60, I don't want to have to replace a belt each year, but it DOES seem to be the cause - the sound corresponds to the belt making a full revolution on the pulleys.
Any other belts I should look at? If I am going to replace it once a year, any cheaper / still quality alternatives?
Thanks!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 07-03-2016, 10:21 AM   #20
scoobynewbie
Drives: 13 GBS BRZ, 05 BRP RS
I am in for the master answer. I get random squeaking, sometimes at idle, sometimes under load, sometimes it goes away when the accel is released... starting to piss me off just like the rest of you.
scoobynewbie is offline   Reply With Quote
Old 07-03-2016, 10:29 AM   #21
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Here's your solution. I said so a year ago, and I say so again.
If you can't get Johnsons Baby Powder where you are, then any fine talcum powder will work well.
Old 07-04-2016, 09:41 AM   #22
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Im only running a V3 with a stock pulley but I run a Bando 6PK2475. Been well over a year with several track days mixed through out. I have never had any belt noise.
cruizin01 is offline   Reply With Quote
Old 07-04-2016, 02:44 PM   #23
wbradley
Sarcastic SOB
wbradley's Avatar
I have the same issue with an HKS supercharger. Happened from day 1 with the replacement unit I installed this year.
Mine starts to squeak at approx 3000 RPM and up when the engine is cold. Even on a hot day this happens but it stops after I run the engine for a few minutes.
I was concerned it was the belt or one of the pulleys but am pretty sure it is inside the blower. My guess is there is a tight fitting bearing or internal rollers that get quiet when things expand due to heat.
I am curious to try the baby powder but sounds way too messy. Definitely DO NOT use silicone spray unless you want your belt to slip.
Old 07-05-2016, 09:48 PM   #24
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
My belt is squeaking as welll, mostly when cold.
If I'm running V2 with stock pulley (I believe) will the Bando 6PK2475 work on that as well? I bought the car with Vortech SC already on there and not sure what size pulley. Best way to measure?
BTW, they sprayed engine dressing when they sold the car and it got on the belts.. I don't think that helped and possibly contributed to this.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 07-05-2016, 09:50 PM   #25
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Pretty sure the v2 uses the same length belt. Assuming the pulleys are the same. The stock pulley on these cars is 3.48"
Sent from my SM-G930V using Tapatalk
Old 07-05-2016, 11:09 PM   #26
DJCarbine
Thupercharged
DJCarbine's Avatar
FWIW ever since I swapped to a goodyear gatorback belt (now continental I believe) I have had zero belt issues. No more squeaks/slipping. YMMV but its worth a shot if you want to try something different
The part number on the belt is not what you need, this is just a stock photo
2013 FRS
Vortech V3 11psi
Old 07-05-2016, 11:14 PM   #27
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
V2, after last track day, started faint but audible squeak when cold and upto 3k rpm (or droned out by exhaust beyond this). I spray water on the belt before i drive off to get rid of embarrassing sound until it gets fully warmed up.
I'm getting annoyed with this supercharger, first SC bearing failure at track (v3), followed by v2 oil return leak in the next year (still pending to be fixed), now with this squeak in 2016. Car still has under 14k miles and probably well under 7k miles with SC for god sakes..
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 07-06-2016, 01:34 AM   #28
FingR-S
FingR-S's Avatar
I just realized I said I had a V2.. I meant V3.. which I suppose makes no difference with the belt squeaking. I bought the car with the squeak knowing that this was something I would contend with. I'm not planning on doing a lot of tracking in any case.
I suppose I can try a couple different belts and see what lasts longer before squeaking. Thinking of getting any possible residue off the belt with soap and water.. or perhaps something else?
I need to measure my pulley so i know whats on there.
Squeaking noise from the steering ScionFR-S Issues | Warranty | Recalls / TSB 22 02-09-2018 05:37 PM
TANABE FRONT PIPE / MEDALION CATBACK / Omni 2.5 bar map sensor / GATES RACE BELT kinryu Engine, Exhaust, Bolt-Ons 3 08-07-2014 06:01 PM
Squeaking noise from wheel oinkoinkpig Issues | Warranty | Recalls / TSB 8 04-26-2014 11:10 AM
Squeaking noise oinkoinkpig Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 12-25-2013 04:26 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
