Old 09-06-2014, 01:52 AM   #15
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
What are you planning on doing for turn signals?
Edit: wait never mind, you're going the other way. Thought you had a BRZ.
Old 09-06-2014, 02:10 AM   #16
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by JDis3 View Post
Refining shouldn't be an issue if I could get ahold of both wiring diagrams
Or you can just do repin n test. That's what I did. The BRZ headlight wiring diagram is on the site. Look up BRZ headlights on FRS on the forum and you should be able to find it. The Monogram series headlights pins are similar to the GT86 pins if it is 8 pin. If it's 6, then its testing time. I can't tell you for sure which pins goes where as I just tested it constantly on mine(I converted my 6pin halogen headlight into the 8 pin BRZ headlight).
Edit: Just notice that you are in NorCal. If you are near SF/DC area I can help you out w/ repinning if needed.
Bach415 is offline   Reply With Quote
Old 09-06-2014, 02:16 AM   #17
JDis3
JDis3's Avatar
Drives: is300 / Fr-s
this is what i ended up finding.
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT
my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz
JDis3 is offline   Reply With Quote
Old 09-06-2014, 02:17 AM   #18
Bach415
Bach415's Avatar
Yup. That is it for the wiring diagram.
Old 09-26-2014, 04:18 PM   #19
JDis3
JDis3's Avatar
bump. does anyone know if the monogram wiring is identical to the gt86?
Old 09-26-2014, 10:18 PM   #20
PhoKingCool
PhoKingCool's Avatar
suscribing
PhoKingCool is offline   Reply With Quote
Old 09-29-2014, 07:54 PM   #21
2SeeKU
Drives: Raven GT86 & Subaru WRX CS6
The wiring in the GT spec is different to that of the monogram/GTS, with a 6 pin connector instead of an 8 pin. That diagram is actually what l made to do the headlight conversion in my car.
If you get stuck, l think l have the wiring diagram for the Monogram/GTS I can upload tonight.
2SeeKU is offline   Reply With Quote
Old 09-29-2014, 07:56 PM   #22
JDis3
JDis3's Avatar
Yes that would be great if you could upload the monogram wiring diagram.
Old 10-07-2014, 01:12 AM   #23
JDis3
JDis3's Avatar
Bump. Can someone please post the 8pin monogram or 10 series wiring diagram. I'm ready to install my Brz headlights already
Old 10-07-2014, 04:15 AM   #24
Bach415
Bach415's Avatar
Have you tried just plugging it in first and see if it works? I don't think anyone has a monogram/10 series wiring diagram. More like the JDM diagram/BRZ diagrams that was posted for you a while back. Your best bet is to label them like I did when I did the repinning and just trial and error. If anything, it should just be only a few pins to repin if I'm correct.
Old 10-07-2014, 10:36 AM   #25
JDis3
JDis3's Avatar
Honestly I'm a bit spoiled from the is300 forums having pretty much every question answered through the search button. I'm not fond of trial error because of my lack of free time. If no one ends up responding, maybe ill take a day to dedicate to the headlights
The Following User Says Thank You to JDis3 For This Useful Post:
nigel-jdmparts (03-18-2015)
Old 10-07-2014, 04:26 PM   #26
Bach415
Bach415's Avatar
Well you do have an older generation IS300 which means more information for that car is out there compared to the FRS/BRZ/86. People had more time to experiment with that car than ours. Also, it seems like most people here with a FRS likes the JDM headlights on the car rather than BRZ headlights so there will be little information about it. It's rare to see a 10 series/monogram series owner who wants to swap their headlights for BRZ ones. Anyways, I'll see if I can check out the monogram headlight wiring first on one of the cars at the meet today then see how I can help you repin it.
Old 10-07-2014, 06:07 PM   #27
JDis3
JDis3's Avatar
That'd be great thanks. I guess the Jdm factor is no longer the most important factor for me anymore haha. Before for me if it was Jdm it must be better. I like the monogram/jdm headlights but imo they don't look as good as the Brz headlights.
Old 10-12-2014, 12:59 AM   #28
JDis3
JDis3's Avatar
Figured out the wiring, will upload pictures when i get around to installing the lights.
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 10:07 AM
Monogram Series FR-S is official! Rio Scion FR-S / Toyota 86 GT86 General Forum 428 02-18-2016 05:06 AM
FRS Monogram vs. Series 10 Xerious Scion FR-S / Toyota 86 GT86 General Forum 92 09-11-2015 03:35 AM
Monogram Series FR-S Orders Rakshaa Scion FR-S / Toyota 86 GT86 General Forum 1241 06-10-2014 11:56 AM
Monogram Series or 2.5L FR-S Chad86 Scion FR-S / Toyota 86 GT86 General Forum 42 11-14-2013 07:16 PM
