Old 09-06-2014, 02:37 PM   #15
litemup
Drives: around
Originally Posted by tomaszjanczak View Post
You seem to be right about the built up oil pressure because if I turn the car off and immediately turn it on, the sound doesn't happen. But if I wait a minute and then turn it on, the sound happens. I do plan on taking to the dealer now, it sounds like a serious problem.
Please share findings. Best wishes on a solid fix.
litemup is offline   Reply With Quote
Old 09-09-2014, 08:27 PM   #16
73TORANA!
Drives: Orange GTS
mine developed a slight sound at start up but not that loud. arter i changed the oil it was ok but after 5000km's its starting to come back. Courious to hear that it goes when the oil light goes out. my old car used to do that but the big ends were shot and that had done 300,000 km's. Get it to the dealler and dont let them tell you its a characteristic like they do with me, good luck and please keep us posted
73TORANA! is offline   Reply With Quote
Old 09-09-2014, 08:36 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes, I regularly check it and it has been good throughout the 4 months since I last changed my oil. I'm planning on changing it today though.
Do yourself a HUGE favor and have the oil analyzed. Even if it turns out to be nothing, you need to make sure there's no excessive wear.
-alex
Old 09-09-2014, 10:38 PM   #18
litemup
Drives: around
@tomaszjanczak, have you taken it to the shop yet?
Old 09-09-2014, 10:51 PM   #19
tomaszjanczak
Drives: Silver Subaru BRZ
No I have not had time but since I had changed the oil on Saturday, the noise occurs only once in a while and when it does, it's very quiet, no where near as loud as before. Most of the time now, the car starts without any noises. I'm using Mobil 1 0w-20 advanced fuel economy. Maybe the oil sucks?
tomaszjanczak is offline   Reply With Quote
Old 09-09-2014, 11:05 PM   #20
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
If you take it to the dealer let me know, I have a similar sound on startup (although less pronounced) and it reminds me of the sound back when I blew my engine on my Mazda 3 ... Scares the fuck out of me every time ..
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 09-09-2014, 11:05 PM   #21
litemup
Drives: around
No, that was a really really ugly metal-on-metal sound. I've heard that sound on a loose old engine where the oil would drain out of the galleys leaving air gaps. The loose rod bearings would knock like hell until oil started circulating and the system regained pressure.
I want very much to be wrong but I'm afraid you may have spun a bearing.
Someone else chime in.
The Following User Says Thank You to litemup For This Useful Post:
tomaszjanczak (09-09-2014)
Old 09-09-2014, 11:07 PM   #22
litemup
Drives: around
^^this
Old 09-09-2014, 11:10 PM   #23
litemup
Drives: around
I'm sorry I missed your post. Yes, this exactly - especially the correlation between oil pressure light and sound.
Old 09-09-2014, 11:12 PM   #24
Simon99
Simon99's Avatar
Is there any way that a spun bearing can be proven if the dealer tells me that's normal and such ? Oil analysis ? Independent garage inspection ? Like that's exactly the sound my Mazda was making at first when I didn't realize it was burning oil like crazy and I ended up starving it ...
[ame="http://www.youtube.com/watch?v=m_dNxOt612I#t=80"]Blown Mazda Engine - YouTube[/ame]
Old 09-09-2014, 11:20 PM   #25
tomaszjanczak
Damn. Is it strange that the noise is now gone or very silent after I changed the oil? The oil level has never been low since I got the car. In fact, the oil level practically doesn't change in between oil changes. Could it be something I did that made this happen, like my driving?
Old 09-09-2014, 11:21 PM   #26
litemup
Drives: around
Used oil analysis. Before the journals shit the bed, they will start fretting and contaminating the oil. Also, oil pressure drops because it flows more freely through the wider gaps in the worn journals.
Old 09-09-2014, 11:22 PM   #27
Simon99
Simon99's Avatar
Do you know if a dealer would recognize a oil analysis ?
Old 09-09-2014, 11:30 PM   #28
litemup
Drives: around
I'm a noob with this engine - another reason I hope I'm wrong. Maybe someone dumped water into your crankcase accidentally? Did you see the used oil?
Be very concerned if you hear it at all the first time you start it in the morning. That deep knock is an expensive sound.
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 01:34 AM
Rattling noise at the rear. Not uniform, but happens often. ZeHeadBanger Issues | Warranty | Recalls / TSB 7 10-22-2013 10:48 PM
Rattling noise under the hood during engine braking at low RPM Sigh-on-Rice Engine, Exhaust, Transmission 60 07-28-2013 08:48 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 12:17 PM
rattling noise in the trunk ayetothejay Scion FR-S / Toyota 86 GT86 General Forum 2 06-27-2012 12:19 AM
