#15 |
It's absolutely not normal.
Have them fix it immediately; it's just a SINGLE adjustment, that should take 2 tries at most with an experienced tech. Quick adjustment, test drive, final adjustment, test drive, done. Under 10 minutes total. |
#16 |
Drives: many
#17 |
Drives: World Rally Blue BRZ
Thanks for the input guys. Will try my best to get a refund on this. Something just ain't right.
On the bright side, I have decided to switch to a quality route within my budget and have gotten myself a set of Konis and now am deciding between Swifts or RCEs. Hopefully this will perform better than this set of cheap-ish coils |
#18 |
Drives: 10 series FRS
Did they check tire pressures before starting the work? Believe it or not, inconsistent tire pressures can pull your car to one side.
#19 |
| DIY Alignment | FRSFirestorm | DIY (Do-It-Yourself) Guides | 41 | 01-31-2020 08:06 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-21-2013 12:45 AM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
| Alignment in GTA? | f0rge | CANADA | 13 | 09-06-2013 01:17 PM |
| where to get alignment? | FML | Hawaii | 2 | 08-08-2012 02:36 AM |
