Old 07-06-2014, 09:50 PM   #15
Lonewolf
Lonewolf's Avatar
Drives: Moped
I think I have another motor the question is do I do another stock or build... Or have the fabricator here in town do the ls1 swap he is offering to do for the cost of materials only since I Already have the motor.
A compact V8 sounds tempting...either way, can't wait to see what you decide to do...
Old 07-06-2014, 09:56 PM   #16
jonbonazza
I feel like a heavy v8 would upset the balance of the car.
jonbonazza is offline   Reply With Quote
Old 07-06-2014, 09:57 PM   #17
Cross
It's the Mad Cow
Cross's Avatar
I'm worried about that to
Old 07-06-2014, 10:16 PM   #18
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
There's a thread titled something like "why do people do swaps" that has corner weights for a ls swapped frs. Very much worth it.
Old 07-06-2014, 11:02 PM   #19
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We have build many FA20 motors. Our motors have been tested extensively. If you have any questions please let us know. Our short blocks does not use any off the shelf parts. All of the components in our blocks are custom to our specs.
FullBlown is offline   Reply With Quote
Old 07-06-2014, 11:07 PM   #20
Reaper
Reaper's Avatar
Drives: violent
I want a fullblown shortblock so bad.
Old 07-06-2014, 11:32 PM   #21
Cross
It's the Mad Cow
Cross's Avatar
I want a motor that's the same compression ratio as stock basically with forged rods, pistons and head studs that's pretty much it.
Old 07-07-2014, 08:20 AM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LSx engines are not "heavy", just a few pounds heavier than FA20 + turbo kit.
@Pure Automotive
@Cross I would do the swap if you trust this local shop and will be left a car that all stock components work. 400+ whp N/A >>> 500+ whp Turbo.
Old 07-07-2014, 08:31 AM   #23
s2d4
s2d4's Avatar
@Pure Automotive
LS3 yeah, isn't the LS1 much heavier?
Old 07-07-2014, 08:39 AM   #24
Sportsguy83
Drives: Limited BRZ
At least from quick research I did online on LS1 and LS3 weight, they seemed really close.
I still might be completely wrong....
Old 07-07-2014, 08:46 AM   #25
s2d4
s2d4's Avatar
Don't have first hand experience but I think Zdan was saying it LS1 was 200lbs more apparently due to being a full iron block.
Should be fun either ways.
Old 07-07-2014, 08:56 AM   #26
Sportsguy83
Drives: Limited BRZ
Yea if its iron block F*ck that....
Old 07-07-2014, 09:33 AM   #27
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
All LS1s are aluminum blocks. The truck variants of the LS series have iron blocks (but not all truck variants were Iron either). The LS engines in Aluminum are all pretty light at the end of the day for what they are. Depending on how the swap is done the weight distribution can be decently maintained.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 07-07-2014, 10:16 AM   #28
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
If you have oil in your engine bay, then my guess is that you "windowed" the block. I look forward to the details so I can add you to my list. @nelsmar is the only one I know with a built motor running relatively high compression, but I believe you two don't get along too well.
'Sloane' - Cali first time build Re~Mix Member's Car Journals 6 06-24-2015 08:22 PM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 08:01 PM
Adventure Time! (E.Ts BRZ/86 Build) E.T Member's Car Journals 4 01-20-2014 01:02 AM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
New FRS owner.. time for a build? sero901 Forced Induction 5 10-24-2013 09:40 PM
