Old 07-04-2014, 01:08 AM   #15
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by jonbonazza View Post
I was informed, however that if it was the o2 sensor, a second code would be thrown as well
Usually when an O2 sensor goes bad, you get an O2 sensor high voltage error.
Old 07-04-2014, 01:09 AM   #16
jonbonazza
I see. Any ideas on what this could be then? Is it really just my tune?
jonbonazza is offline   Reply With Quote
Old 07-04-2014, 01:10 AM   #17
Fastbrew
Drives: 2014 Pearl White BRZ
Oh - what's your MPG been like? Has it been around an avg of 20MPH?
Fastbrew is offline   Reply With Quote
Old 07-04-2014, 01:14 AM   #18
jonbonazza
I honestly never monitor my MPG. I don't have a very long commute (maybe a mile each direction), so the only real miles I put on it are on the weekend.
Old 07-04-2014, 01:16 AM   #19
Fastbrew
You can check it on your dash if you scroll through the readouts. Anyway - I was just curious. If it was something like 35 or something - then you might be pretty lean....
I just saw a lot of people get 30. I guess I am a bit of a hoon.
Anyway GL!
Old 07-04-2014, 01:19 AM   #20
jonbonazza
Just checked and Avg. is 14.8. Not sure how long that takes into account though because most of my driving is city (SoCal, so lots of stop and go) and I have been to a track day every month for the last 3 months.
Old 07-04-2014, 01:23 AM   #21
nelsmar
Was your intake installed before or after your tune? Was anything installed after your tune? Do you have any logs? Preferrably ones that involve a bit of driving (more than just a full throttle pull). I'll gladly take a peak for you. The AEM intake cheats the MAF and if you were tuned pre-intake and installed it your maf reading can be off thus leaning the engine out.
15AFR is normal under cruising / idle, the ecu goes into closed loop and will swing in certain ways for multiple reasons. Also going over 19AFR while engine breaking or engine decel is normal it is actually the ecu shutting off the injectors completely and the sensor simply doesn't have a readout for "no fuel".
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Astroboy (09-03-2014)
Old 07-04-2014, 01:24 AM   #22
nelsmar
14.8 AVG or 14.8 at that moment? There are two readouts. One for avg one for the currently being consumed calculation.
Old 07-04-2014, 01:24 AM   #23
nelsmar
I think this is too lean
http://www.ft86club.com/forums/showthread.php?t=56141
I only pointed that out to show how long it takes to actually do major damage.
What fuel do you usually run?
PS - that sounds very lean to me Again - someone may tell me I'm wrong but crikey....
lol... Epic response. :P
Old 07-04-2014, 01:26 AM   #24
jonbonazza
That's the average.
Old 07-04-2014, 01:33 AM   #25
nelsmar
That's the average.
How long ago did you reset that...???
And any logs?
Old 07-04-2014, 01:36 AM   #26
jonbonazza
And any logs?
I have never reset it manually. Unless unplugging the battery will do so... In which case about 2pm today. Haha
Old 07-04-2014, 02:18 AM   #27
steve99
Removing battery terminal will reset ecu and clear DTC/CEL codes as well as reset learned fueling and ignition timing parameters and a bunch of other counters.
listen to @nelsmar you need to get some logs of general driving to see what going on.
as nelsmar said AEM intake will require MAF rescale or you could get problems and CEL codes you describe was it installed after tune ? also leaky exhaust gaskets near either 02 sensor or engine can throw readings off and cause rich/lean issues did you use new gaskets when headers installed if you re-use the originals they tend to leak after about a month. ??
If you can't do propper logs (torque is a bit slow refresh rate and cannot log all the required parameters) take it back to tuner before it gets worse and more expensive.
If it was me I would not be going WOT with that cel code coming up.
Old 07-04-2014, 02:23 AM   #28
jonbonazza
AEM Intake was installed before tune. Tune took intake into account. Brand new OEM Subarau gaskets were used for header and OP. I can take logs using ECUFlash software. What RPM ranges do you suggest I log?
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
PO171 SYSTEM TOO LEAN BANK 1 rmdrag0n Engine, Exhaust, Transmission 23 03-02-2014 12:50 AM
Recommendation for lightweight wheels without breaking the bank ayau Tracking / Autocross / HPDE / Drifting 6 11-08-2012 02:23 PM
Bank Robbers Throw Money In Police Chase travace Off-Topic Lounge [WARNING: NO POLITICS] 5 09-13-2012 01:00 PM
Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 3 04-29-2012 07:43 PM
