Syste!m too lean bank 1
So do I have a faulty o2 sensor, or is something else wrong?
Sent from my Nexus 7 using Tapatalk |
#2 |
Drives: 2014 Pearl White BRZ
Stock or modded?
#3 |
Sorry probably should have mentioned. Here is the mod list that for the engine:
Invidia N1 cat back Invidia catted FP Motiv OP FT86SF catted header AEM intake ECUTek tune Nothing has changed in a month or so. Just came on on the drive home from work today. Sent from my Nexus 7 using Tapatalk |
#4 |
Geez - hate to make guesses but it could be a ton of stuff. Maybe as simple as the sensor but possibly dirty or faulty injector(s). Maybe the tune needs a little tweak.
I'm going to step aside and let a pro give you better advice but I would start with the cheap stuff and move up the chain. Dealer might not be much help
#5 |
Yea, i need to do another logging run anyway, so i figure ill monitor them at the same time. If the sensor was bad though, wouldnt the logs be skewed?
Sent from my Nexus 5 using Tapatalk |
#6 |
Okay so I did some logging this evening and the afrs regularly went into the 15s. Also, every time I shifted or let off the gas (but NOT stopped in neutral) my afrs were exactly 20. I think this is just how the reading is done. This was using the Torque app for Android.
What is considered "too lean" for this car? Sent from my Nexus 7 using Tapatalk |
#7 |
I think this is too lean
![]() http://www.ft86club.com/forums/showthread.php?t=56141 I only pointed that out to show how long it takes to actually do major damage. What fuel do you usually run? PS - that sounds very lean to me Again - someone may tell me I'm wrong but crikey....
#8 |
91 is the best I can get (easily) in my area. I feel like it's too lean too, but it's weird that I have been on this tune for a couple thousand miles and this just happened out of nowhere. I was informed, however that if it was the o2 sensor, a second code would be thrown as well, and I am assuming the same for a fuel injector, so I guess I'll get some EcuTek logs and hit up my tuner.
#9 | |
What has your MPG been like? |
#11 |
#12 |
#13 |
| lean at idle only | woode | Forced Induction | 5 | 05-03-2014 04:48 PM |
| PO171 SYSTEM TOO LEAN BANK 1 | rmdrag0n | Engine, Exhaust, Transmission | 23 | 03-02-2014 12:50 AM |
| Recommendation for lightweight wheels without breaking the bank | ayau | Tracking / Autocross / HPDE / Drifting | 6 | 11-08-2012 02:23 PM |
| Bank Robbers Throw Money In Police Chase | travace | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 09-13-2012 01:00 PM |
| Scion FR-S FIRST DRIVE Tour in Baltimore at M & T Bank Stadium | ft86Fan | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-29-2012 07:43 PM |
