Old 07-02-2014, 07:58 PM   #15
Tromatic
Originally Posted by Trettiosjuan View Post
How much latitute in stock ecu for low blend E85 flexfuel?
Dunno, but you are going to be our tester! Test to destruction, to be sure!
Tromatic is offline   Reply With Quote
Old 07-03-2014, 02:27 AM   #16
poptopclk
Drives: Scion FR-S 10 Series
It is this simple. Get the OFT OTS E85 ELH Tune and just run E-85 all day long.
You'll get an extra 30 HP and save the environment. Just use the correct oil at next change
My local tuner charged me $40 & I now run ONLY E-85
SIMPLE as that.. YES !
poptopclk is offline   Reply With Quote
Old 07-03-2014, 04:16 AM   #17
Trettiosjuan
Drives: GT86
I had the exact same thing come at me in my sleep
I had another look at the economies here and running E85 pure would save me 25% on my fuel bill, which would equate to you guys saving approx. 60% (on your much lower US bill) in absolute monetary terms!!!
The problem is that it is illegal and it would definitely void warranty if you have any problems. E20 in your tank nobody would notice, E85 sure as...
Once you open that door... 😂
Trettiosjuan is offline   Reply With Quote
Old 07-03-2014, 05:42 AM   #18
SPCorBUST
SPCorBUST's Avatar
I had to take off my Moto-East FlexFuel kit for an inspection and had 3/4 91 in the tank with 1/4 E85 after a computer reset.
The car will adjust, but it will be running lean, may throw some codes, and you won't have the power. I drove it for 90 miles before the lean went away and it felt a little more normal. After 150 miles I think the level was back to mostly 91 (I think its the same as E10 here?) and it felt like the stock car again. (I also recently removed the supercharger)
Moto-East FF kit is a good way to go, but if you don't want to pay for the Ecutek on top of the tune and sensor I'd just go with the $499 OFT and call it a day.
Hope this helps!
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Trettiosjuan (07-03-2014)
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 05:28 AM
running e85 without flexfuel kit? kingkai23 Forced Induction 9 04-21-2014 01:07 PM
synthetic blend on first oil change jp_r6 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 01-21-2014 11:55 AM
California may switch to winter blend gas early jeebus Engine, Exhaust, Transmission 33 10-09-2012 12:44 AM
Flexfuel Allch Chcar Scion FR-S / Toyota 86 GT86 General Forum 50 11-04-2011 01:39 AM
