Old 01-16-2014, 09:38 AM   #1
jp_r6
synthetic blend on first oil change
I spoke to a tuner yesterday that works on a lot of Scooby's and he said to ease the brz into full/100% synthetic oil by using a synthetic blend 5w30 on the first oil change. any comments?
jp_r6 is offline   Reply With Quote
Old 01-16-2014, 11:19 AM   #2
bluesubie
The BRZ comes with Idemitsu 0W-20 "synthetic" from the factory. It has additional levels of ZDDP compared to the dealer Idemitsu oil, which I presume is to help with break-in.
Switching to a blend first used to be recommended for Subaru's (by some people) when they came with "conventional" oil from the factory, but it doesn't make sense to switch from "synthetic" to "synthetic blend" and back to "synthetic".
And stick with the viscosity recommended in your manual, unless you can show that 0W-20 doesn't work in your application (via used oil analysis, oil pressure not sufficient, etc.).
-Dennis
bluesubie is offline   Reply With Quote
Old 01-16-2014, 11:35 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Please let us know what tuner this is. I'd like to avoid him.
-alex
Old 01-16-2014, 12:55 PM   #4
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
-alex
He probably also has some advice on how to properly maintain the BRZ's AWD system.
nocturne1 is offline   Reply With Quote
Old 01-16-2014, 10:16 PM   #5
reardrv
Drives: 2013 Subaru BRZ
My advice to you would be to find a different tuner. As for oil I would definitely use 0W-20 synthetic, which shouldn't be hard to find since I'm pretty sure all 0W-20 oils are synthetic. As for which 0W-20 to use, I'm not touching that one with a 10' pole. Lol.
reardrv is offline   Reply With Quote
Old 01-16-2014, 11:28 PM   #6
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
There have been a bunch of very strange threads as of late by members with little to no previous posts that well let's just say sound really rediculous. If your tuner doesn't know that our cars come stock with synthetic. Run for z hills.
Dwood11 is offline   Reply With Quote
Old 01-17-2014, 09:04 AM   #7
jp_r6
Ok thanks for the input guys. First This guy is not my tuner and probably never will be, I prefer to do my own tuning and what I can not do I have a excellent mechanic for that. I did change my oil and stayed with synthetic since it just sounded odd to use a blended oil in such a modern engine. My question was only because this is my first Boxer motor and I normally never sell a car case in point my 07 Tahoe has 170 000 miles on and still running strong, so I want the same for my BRZ. Thank you again.
SO FOR ALL THE NEW OWNER - STAY WITH THE FACTORY OIL STOP QUESTIONING, JUST READ YOUR MANUAL
Old 01-17-2014, 11:50 AM   #8
mav1178
mav1178's Avatar
I'd still like to know what tuner this is, so I can avoid him.
-alex
Old 01-17-2014, 11:52 AM   #9
OrbitalEllipses
Drives: Attitude
Must think all boxer engines are the same. That'd work for an EJ, not for the FA.
Old 01-21-2014, 10:55 AM   #10
frs10
Drives: tezla
oh man... he went there... and i dont mean jared
frs10 is offline   Reply With Quote
Subaru Synthetic oil 0w-20 alex_86 Mechanical Maintenance and Tools 1 09-27-2013 09:14 PM
Top Synthetic Oil for FRS...opinions? forzajuve Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 04-24-2013 11:33 AM
Is FR-S oil Synthetic or Conventional? EBMCS03 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 52 01-08-2013 10:37 PM
Subaru Oil All Synthetic? DaJo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 11-07-2012 10:47 AM
California may switch to winter blend gas early jeebus Engine, Exhaust, Transmission 33 10-08-2012 11:44 PM
