#15 |
Drives: 2JZ FRS
If 1000hp axles aren't really needed, you don't need a diff swap. I only broke one set of stock axles with 600whp on drag radials. Stock diff is fine. I'll be around 800whp on a stock diff and driveshaft shop axles this season.
#16 | |
Drives: 2013 Scion FR-S + 2011 Yamaha R6
#17 |
Drives: 2JZ FRS
we use this kit in our 2jz drag car. mostly for the axles and ability to change the gear ratios relatively quick/cheap. for an fa20 the oem diff should never really be an issue power wise
| DIY - Differential and Ring & Pinion Swap | Dustin | DIY (Do-It-Yourself) Guides | 126 | 07-01-2019 10:29 PM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Anyone have a differential pop yet? | slicktop | Engine, Exhaust, Transmission | 6 | 02-26-2014 08:22 PM |
| Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ | JPxM0Dz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 05-05-2013 05:12 PM |
| Eww rear differential goo | LeeMaster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 04-10-2013 09:17 PM |
