Old 06-23-2014, 05:00 PM   #15
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by Kronos View Post
I definitely use my whole leg to clutch in. Size 13 shoe. Like N1rve said, I don't think pivoting on the heel would provide a big enough range to clutch properly . Plus your leg muscles are stronger, so once you get the muscle memory down it allows for more control in my opinion
Strength and precision (control) do not typically go hand in hand. Think about writing, typing....you're making find adjustments with small muscles and tendons.
I wear size 12/13 depending on the brand. My clutch is properly adjusted, as is my seat and seat back. I pivot off the floor. But this is also my first manual car so I have done what feels right.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-25-2014, 10:56 PM   #16
schmearcampain
Drives: 2014 Argento FRS 6MT
Heel off to press down and heel on when I lift off. Never gave it much thought and I certainly don't do it intentionally. Been driving MT my whole life. Size 13 shoe.
schmearcampain is offline   Reply With Quote
The Following User Says Thank You to schmearcampain For This Useful Post:
hmong337 (06-28-2014)
Old 06-26-2014, 12:40 AM   #17
CatDaddysBBQ
Drives: '13 FR-S
Heel on floor. Size 13. Otherwise get used to a float.
CatDaddysBBQ is offline   Reply With Quote
Old 06-26-2014, 01:23 PM   #18
AlexWood
Drives:
I'd say do what is most comfortable for you. As long as you can fully depress and release the pedal then it doesn't really matter. I watched a video at one point (I believe it was a mighty car mods video) where they said to make sure your seat is close enough so that when you fully depress the clutch pedal, your legs have a slight bend in them. This is so that if you were to get into an accident and you have the clutch mashed down, your leg doesn't break from the collision, it would just fold back towards you. Just a tid-bit of knowledge that seemed to make sense to me.
AlexWood is offline   Reply With Quote
Old 06-26-2014, 03:17 PM   #19
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Size 9 and i keep heel on floor....unless im on a long drive and my foot muscles start getting tired in traffic then i may start using my leg..lol
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 06-27-2014, 11:40 AM   #20
DeadStar7
Retired formula car racer
DeadStar7's Avatar
Drives: 2013 Scion FR-S Manual
For better clutch control, definitely keep your heel down. It's only the n00bs that use their whole leg. 😉
DeadStar7 is offline   Reply With Quote
The Following User Says Thank You to DeadStar7 For This Useful Post:
Old 06-27-2014, 12:25 PM   #21
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I stomp the shit out of my clutch because I have tiny Asian feet.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Zed (07-09-2014)
Old 06-27-2014, 12:48 PM   #22
FR-S89
do you guys kick the clutch in very quickly?
I know on the clutch release i'm very smooth and let go gradually to make a smooth shift. but when im engaging the clutch i just kick that mofo in with my leg as fast as possible. Is this ok to do? first MT car
FR-S89 is offline   Reply With Quote
Old 06-28-2014, 12:22 AM   #23
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
I keep my heel down, but I was only able to do that once I adjusted the clutch closer to the floor. Highly recommended.
Scaldy is offline   Reply With Quote
Old 06-28-2014, 01:00 AM   #24
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Heel off the floor and use leg when pushing the clutch in. To slip with accurate precision, I release the clutch by pivoting my ankle. I've been driving manual my whole life.
I once had a back seat passenger "wtf'd" to find out that my car was a manual after 30 minutes of riding because my driving was so smooth. He thought my car was an auto only to find out I was rowing gears the whole time
hmong337 is offline   Reply With Quote
Old 06-28-2014, 10:40 AM   #25
CoupedUpSubie
Drives: 2013 BRZ Limited
Biggest thing is make sure you are off the throttle completely. As for slamming the pedal down you should be fine as long as you aren't bending anything. On release make sure you aren't being too gradual as that will shorten clutch life. Shifting my old impreza was kick down and shift at the same time, slide foot off to the side. That was go "fast" mode.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 06-28-2014, 10:47 AM   #26
DeadStar7
DeadStar7's Avatar
Yes sir! After letting it out a bit slower in first gear, feel free to pop it out quite quickly as well through every other gear. Just play with different timing if you're going to pop it quickly. If you punch the clutch in, ram the next gear, then pop it out, it's probably not going to be too smooth. Just give it half a second or so between gears to let the RPM's drop a bit before letting the clutch out. Ideally, for the smoothest shift you want the RPM's to drop to where they will be in the next gear when the clutch pedal is released. Don't over think it or you'll get frustrated. Just play with different timings.
Once you master this, we'll get into rev-match shifting for down shifting, then shortly after heel-toe shifting. It's not as hard as you might think. Just takes some practice.
Old 06-28-2014, 10:47 AM   #27
DeadStar7
DeadStar7's Avatar
...or don't use the clutch at all.
Old 06-28-2014, 12:50 PM   #28
paulca
Drives: Toyota GT86 Coupe Red (UK)
Really. Try that on an old non-hydraulic clutch that has 10" of travel and needs about 10Kg of force and the bite point is right on the springs strongest point.
Heel up to push the clutch full down, then put the heel down if/when it suits you to stabilize your leg/foot on the bite point. You can also "wedge" the pedal against the ball of your foot, heel on the floor for long hill holds and still have some flex in your foot to adjust it
I have never driven an auto.
As to "riding the clutch", just don't push it! I sit with my foot on the clutch 99% of the time and it's never once been an issue. Just as long as you don't sit with too much pressure on it to where the clutch will slip, overheat and/or burn out eventually. In the GT86 my foot defaults to remove the freeplay out of the pedals as soon as my foot is on them, clutch included and that is a good 2 inches of travel.
paulca is offline   Reply With Quote
seat positioning rainmonkey Cosmetic Modification (Interior/Exterior/Lighting) 23 12-07-2015 09:38 PM
Gauges Positioning BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 12 12-10-2013 08:24 PM
Anyone here with a foot fetish? switchlanez Off-Topic Lounge [WARNING: NO POLITICS] 47 04-08-2013 03:27 PM
Go Pro Positioning mechaghost Tracking / Autocross / HPDE / Drifting 7 12-15-2012 02:22 PM
