Old 06-16-2014, 10:22 PM   #15
Dezoris
Dezoris's Avatar
Originally Posted by mav1178 View Post
So weird... I have RE30s 17x8" +44 with 235/40-17 tires, and with -2.5 camber up front I have zero issues with rubbing at the track.
You and I run the same suspension... I can't believe it makes that much difference, unless you're running sticky R-compounds.
-alex
RS3, far from R compound but sticky. Glad I did go 245 on these wheels.
Originally Posted by glamcem View Post
I had some rubbing issues yesterday that I never experienced in another track before so it really depends on the track and the compression on the springs ..Just because you didn't experience any rubbing issue so far doesn't mean you have no issues
to the OP, how much did you lower car? what are your spring rates? have you tried changing the dampening settings?
FYI, I have +35mm offset and I am lowered 1.5" all around. I have the similar camber -3.0 Front and -2.7 Rear. You should definitely try raising the car up a bit and change it to 17x9 +35 RPF1, any particular reason you picked 17x8 +42 over the 17x9 +35? since slightly wider wheels definitely improve the mechanical grip
I am only dropped 10mm front and rear, on 346/346 springs. Ohlins dampers were at 7F 6R. I chose 42mm because I dont like the wheel coming that far out of the fender.
Originally Posted by diss7 View Post
Do you have 235/45 tyres? If so, going down to a 235/40 will probably be the cheapest way (other than a slip on spacer) to solve this.
235/45 odd.
Old 06-16-2014, 10:41 PM   #16
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
My first thought when I read your first post was the height of your tires. I would run a 235/40 instead of a 45 series.
But your question was what is a good wheel size and offset?
Start at +35. Whether 8 or 9" wide, it's a great offset for our cars. 17x8 +35 with a 245/40R17 would be a good combo, or run a narrower tire like a 235/40 or 225/45 tire.
Btw, why so much camber? Are you tracking, autocross or just street? You may want to consider trimming back your camber to closer to -2 to -2.5.
Slick is offline   Reply With Quote
Old 06-16-2014, 11:44 PM   #17
Dezoris
Dezoris's Avatar
Track and autox, I was running -2.1 in front and was not enough.
I will look at 35 wheels next and 245/40
Old 06-17-2014, 12:19 AM   #18
Pete156
I like to eat!
One has to remember that not all manufacturers 235/40s are the same width. They should be by definition, but they are indeed not so.
Pete156 is offline   Reply With Quote
Old 06-17-2014, 06:27 AM   #19
Originally Posted by Dezoris View Post
I have RPF1 17x8 42 offset with 235 tires. Now that i have -3 camber up front thr wheel is rubbing on inside fender liner near brake line when under harder turns.
So annoying. Is the solution a lower offset like 40? Or what?
Raise the height, or use a small spacer. It's bound to happen with enough compression; I see it on almost every track car.
Dezoris (06-17-2014)
Old 06-17-2014, 06:22 PM   #20
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
that should definitely help since you're overall height of the tires are 25.4" compared to 24.7" OEM size.. like I said I have been running 235/40/17 and those are about .3" shorter than the OEM size ..even still front tires rub at certain corners , I will also try raising the car a bit but in your case it may not be needed after changing the tires..
FYI, 255/40/17 Nitto NT01s are still closer to the OEM size 24.92" and I think you should definitely benefit since you auto-x with a SC kit and people at rennlist forums run them to the cords and flip them if the outside wear is more than the inside haha
glamcem is offline   Reply With Quote
Old 06-17-2014, 08:27 PM   #21
CSG David
CSG David's Avatar
It's not about the offset issue. You need to raise the car a bit. Trust us, we've burned through the liner too.
Old 06-19-2014, 12:31 AM   #22
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
I don't think anybody mentioned that one of these vehicles might have more positive toe with regards to their alignment settings. That would possibly explain why the +44 offset member isn't rubbing inside while the +42 one is. Naturally section widths from manufacturer to manufacturer will vary, even though they say they are the same size.
AutoRnD is offline   Reply With Quote
Quick question?!?! tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-18-2014 02:55 PM
A Quick Question! emerald_ir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-18-2014 07:43 AM
New guy with a quick question Bullnettles Engine, Exhaust, Transmission 28 05-09-2013 12:03 AM
Quick vid of new Nameless Offset revised system GTB/ZR-1 Engine, Exhaust, Transmission 35 02-07-2013 07:02 PM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 09:53 PM
