Old 06-16-2014, 12:39 PM   #15
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by paulca View Post
You get more fuel if you fill on a cold day.
That's a myth. Fuel of course is stored in underground tanks, and the tank temps are essentially constant.
" Filling Up When It's Cold Outside
Get your gas in the evening or early morning - the fuel is cold, and therefore denser. The truth about this myth is that you can barely register a temperature difference, since gas is stored in cool underground tanks, so fill up when you want. There are no savings to be had by waiting until it's cool out."
http://www.investopedia.com/financia...ally-work.aspx
billwot is offline   Reply With Quote
Old 06-16-2014, 02:20 PM   #16
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Where I used to live in California we had VP Racing and they had 95 AKI and 102 AKI fuels on separate pumps. 95 was $4.99 and 102 was pushing $8/gal I believe...That was 2008 when I last paid attention to that stuff though, when I had my S/C'd GTO (Vauxhall Monaro for you Brits ).
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-16-2014, 02:29 PM   #17
paulca
Drives: Toyota GT86 Coupe Red (UK)
I should have added a smiley. It was part "tongue in cheek".
We are talking about few cubic inches a gallon for 20F degree shift.
Winter and summer, you might be able to measure it in some regions, but it's not going to make an impact on your fuel bill unless you can buy your summer fuel in winter and store it.
The gas industry apparently defines a gallon, a gallon at 60F.
In aviation when filling an airliner, you get your fuel in Kilos or Lbs because that matters and makes load sheets easy. Instruments are usually in Lbs per hour or Kilo per hour, because weight matters more than how full the wings are. However, the density and temperature of the fuel are noted when ordering and if beyond limits the fuel load adjusted. The fuel may get pretty damn cold at 40,000ft.
paulca is offline   Reply With Quote
The Following User Says Thank You to paulca For This Useful Post:
Shedd22 (06-16-2014)
Old 06-16-2014, 04:52 PM   #18
hur1ey02
hur1ey02's Avatar
Do warm climate areas (Cali and FL) switch to the winter blend fuels? Just curious.
Amanda - 2013 Scion FRS (Raven)
hur1ey02 is offline   Reply With Quote
Old 06-16-2014, 05:14 PM   #19
Wheelsoffracing
Wheelsoffracing's Avatar
Drives: 2013 Firestorm FR-S
I just paid $3.55 a gallon for 93 octane (Pilot) here in Virginia. Shell is always about $.10 to $.20 more a gallon than most of the others so Shell is $3.75 now for 93 octane.
Wheelsoffracing is offline   Reply With Quote
Old 06-16-2014, 05:41 PM   #20
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Yes we do.
Right now 91 oct is $4.39/gallon @ my local shell station.
100 Octane? hellyvin Northern California 23 07-24-2017 09:01 PM
93 Octane vs 91 Octane keithgold Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 01-16-2014 11:16 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
110 octane EZWood Engine, Exhaust, Transmission 19 06-29-2012 09:12 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 01:22 PM
